GE - Refrigerator Section Freezing - Appliances - DIY Chatroom Home Improvement Forum
Old 12-05-2013, 07:57 AM   #1
raylo32's Avatar
Rewards Points: 1,254
GE - refrigerator section freezing
Friend has a GE, about 10 YO, that the reefer section is freezing. What part of the control is likely to cause that? A bad temp sensor or perhaps thermostat? I don't have the model number but wll try to find out and post in case there are known common issues with his model.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 12-05-2013, 08:03 AM   #2
Rewards Points: 13,468
The model # is key.
http://www.repairclinic.com/RepairHe...-freezing-food
Old 12-05-2013, 09:04 AM   #3
Model number will help but more than likely the damper that allows the air from the freezer into the refrigerator is stuck open or there is a bad temperature sensor in the fridge. The exact cause depends on the model, side by side, top freezer...
jfrotten is offline   Reply With Quote
Old 12-05-2013, 09:34 AM   #4
raylo32's Avatar
Thanks, guys, I'll pass this info along an hopefully get the model and configuration. Alls I can recall is last time I saw it it was full of beer!
Heat pump condensers freezing over sktn77a HVAC 8 02-05-2013 04:27 AM
Repointing - Antihyrdo in high lime mortar, Freezing cconsentino Concrete, Stone & Masonry 3 12-11-2012 03:01 PM
Pipe freezing mitch08 HVAC 9 05-29-2012 11:14 AM
Water may be freezing, need help asap GuyFromTheNorth Plumbing 9 01-23-2011 04:41 PM
freezing pipes / bad insulation plumber red Plumbing 10 01-30-2010 05:46 PM
