GE Refrigerator Doesn't Hold Temp - Appliances - DIY Chatroom Home Improvement Forum
Old 12-19-2009, 11:18 PM   #1
GE Refrigerator doesn't hold temp
I have a GE side by side (model - GSS25 WGPD). The refrig. temp goes to around 50F or higher. Then the freezer thaws a bit. I can see frost at the back of the freezer. (I opened the back panel but no ice on the condenser). Then it seems like it starts to work and temp goes all the way down to 30F in the refrigerator & the freezer side freezes. Again the temp goes up to 50 and the cycle repeats again. I had the sensor on the refrigerator side replaced last year (by a repairman who tried trial and error method and replaced pretty much every part including the circuit board etc and finally settled on the sensor! I wouldn't want to call him again). Any suggestions/advice before I call another repairman?
martinia is offline   Reply With Quote
Old 12-20-2009, 08:00 AM   #2
sounds like fan in frz isn't working properly. when it warms up is compressor running,fan in frz running?? this refrig is a little tricky to service. as you found out you have to know what you're doing. i would call a local guy, smaller, [1/2 page or less] in phone book and ask him up front if he's knowledgeble on the GE Artica's. although it worked for a year, who knows what first guy did. don't despair, competent servicer can fix this refrig no problem.
Jacques is offline   Reply With Quote
Old 12-30-2009, 12:09 PM   #3
Thanks for the suggestion. I think it is the fan as well. For e.g., if the temp on the top shelf of the refrigerator side is around 45F, the bottom shelf is around 31F.
How to use Simpson Hold downs for gaurd rails rocketdoctor Building & Construction 22 05-11-2010 02:56 PM
Best High Temp Paint for wood stove?? Sellncars Painting 9 01-21-2009 06:21 PM
Attic Temp Measurments - VA ChrisCM HVAC 2 06-13-2008 08:59 AM
Trying to get screws to hold in soft wood fw2007 Carpentry 1 08-22-2007 09:20 PM
Kenmore Refrig. Temp. ? kourso Appliances 1 07-09-2007 11:37 AM
