GE Refrigerator Defrost Problems (with Pics) - Appliances - DIY Chatroom Home Improvement Forum
Old 03-26-2012, 12:54 PM   #1
Rewards Points: 276
GE refrigerator defrost problems (with pics)
I'm not finding a solution to this problem on the web. One source tells me that the drain tube is clogged but there is no drain tube. The water collects on the bottom of the refrigerator under the crisper drawers on my GE french door bottom freezer model. As you can see, there is also some ice up in the freezer vents. I suspect it it just overloaded and needs to be unloaded and defrosted but am looking for advice and have posted pics.
GE refrigerator defrost problems (with pics)-p1000399.jpg   GE refrigerator defrost problems (with pics)-p1000400.jpg   GE refrigerator defrost problems (with pics)-p1000401.jpg   GE refrigerator defrost problems (with pics)-p1000402.jpg
Jim F is offline   Reply With Quote
Old 03-26-2012, 01:56 PM   #2
Rewards Points: 13,472
Open the freezer and rmove the screws holding on the cover on the left side.
Once removed you should see the tube there talking about.
Mine was frozen right at the top of the tube so I used a hair dryer to melt it then a piece of wire down the tube to clear it all out.
Old 03-26-2012, 07:46 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
yeah, it has a drain tube. Take the cover off the evaporator and you should be able to find it.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 03-26-2012, 08:14 PM   #4
Rewards Points: 276
Thanks for the replies so far. I will have to do some more digging tomorrow. The second picture I posted is of the bottom of the refrigerator. This is the area I found to be full of water that is cleaned out before the picture. I could not remove that shelf above the cover so could not see behind it. Is that where the drain hole is? Or is it down in the freezer campartment?
Are there any tricks to removing the shelf in the refrigerator section. Also, does the freezer pullout drawer come off without too much trouble to gain access to the back of the freezer?
Old 03-27-2012, 01:48 PM   #5
Rewards Points: 276
So here is what I've come up with. I was originally thinking there was drain hole in the floor of the refrigerator behind that thing that holds the water for cooling. That is not the case. I did go down into the freezer and open the condenser cover as suggested above and realized that is not my problem.
GE refrigerator defrost problems (with pics)-p1000403.jpg   GE refrigerator defrost problems (with pics)-p1000404.jpg   GE refrigerator defrost problems (with pics)-p1000405.jpg   GE refrigerator defrost problems (with pics)-p1000406.jpg
Old 03-27-2012, 01:57 PM   #6
Rewards Points: 276
Apparently my problem stems from the fact that the ducts that bring cold air up from the freezer are aced up. This required me to carefully defrost this area with a hair dryer. I say carefully because if you get into a hurry, you can melt the plastic inside a refrigerator. I have done this in the past, fortunately not on this one.
This brings me to the real problem of ice building up in the refrigerator which can be the defrost timer or defrost heater. I am hoping that it is just due to overloading the refrigerator and having the temp set too low. It was set at 36 F.
I also pulled the refrigerator out and vacuumed out behind and underneath it where the heat exchange occurs on this model. So, it must be pulled out of its cabinet space and vacuumed periodically rather than having access in the front.
I am hoping this solves my problem but will have to keep an eye on it. As always, I am open to advice.
GE refrigerator defrost problems (with pics)-p1000408.jpg   GE refrigerator defrost problems (with pics)-p1000409.jpg   GE refrigerator defrost problems (with pics)-p1000410.jpg
Old 03-28-2012, 10:18 PM   #7
Rewards Points: 276
Update. Already, a day later I am sponging up water in the bottom of my refrigerator. I am just not finding any answers online. Before I call for service, is there any other advice out there?
One other thing worth mentioning: As you can see from this project picture, the refrigerator is somewhat enclosed in its own cabinet. Is it possible that the evaporator is just not getting enough air exchange?
Old 03-29-2012, 06:43 PM   #8
Rewards Points: 276
Is there some sort of drainage channel in that duct in the back of the refrigerator that is blocked? If so, how do I access that? I did take out the screws once and try to remove it but felt a lot of resistance so thought I might cause damage if I persisted.
Old 04-16-2012, 07:42 PM   #9
Rewards Points: 276
Two things I found out about this. The first thing is that it is still under the 4 year service contract I bought with it at Lowes. I found that paperwork and called in service.
The second thing I found out is that there is actually a second evapoprator behidt that duct cover in the back of the refrigerator and there is where the frozevn over dreain tube was found.
Also they had a design flaw in the refrigerator evaporator fan where it was kicking on too soon and drawing water up to the top after the defrost cycle and refreezing there. So, they replaced cover and duct which also has the fan attached to it. Unfortunately, I didn't get pictures of it when the tech had it apart.
Old 10-11-2012, 03:07 PM   #10
Jim F, Have you found the solution to this? I have the same problem that you mentioned. I have been looking on internet for a solution and havent found anything. The only solution that I found is to unload all the food and leave the doors open. It will melt the ice in the back and the refrigerator will work well again but it will just last for a month.
Rafael07 is offline   Reply With Quote
Old 10-12-2012, 10:30 PM   #11
Is this the solution to the refrigerator? Please need and answer. I have been looking for a solution for about 3 months. Plz help
Old 10-13-2012, 08:37 AM   #12
#1 HAWKEYE FAN
instead of just letting it defrost manually , shut down the refrig, take the cover off of the evaporator and look at the defrost drain hole. It will be iced up and likely frozen down inside the drain tube. Defrost the tube then find a wire that is flexible enough to slide down the tube and clean it out. Since you did not post your model # it is hard to say if Jims fix would be the same fix for yours
The Following User Says Thank You to hardwareman For This Useful Post:
Rafael07 (10-13-2012)
Old 10-13-2012, 09:32 AM   #13
Same model as Jim F.
Old 10-13-2012, 10:06 AM   #14
#1 HAWKEYE FAN
ok, then yes Jims solution should work for you also. GE has had lots of issues with their bottom freezer units. I would take it apart first and clean the drain tube and see how long it last. If it continues to give you the problem then maybe call in a GE tech to service it, as they should have all the latest update procedures for repair.
Old 10-13-2012, 10:12 AM   #15
The drain is in that metal pan with the duct tape on it, under the coil.
97 acura 3.2 TL with multiple problems vonbismarck Automotive Repairs 5 02-13-2012 11:00 PM
Finishing basement with pics badbuz Building & Construction 4 02-24-2010 09:31 PM
The award for the dampest, smelliest basement closet goes to...Pics enclosed. TjbDIY Building & Construction 1 08-28-2009 03:59 PM
Kitchen Project Complete with pics! baksdak Project Showcase 30 03-10-2009 02:13 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
