GE Refridgerator With Low Water Pressure - Appliances - DIY Chatroom Home Improvement Forum
Old 01-13-2012, 09:02 AM   #1
Rewards Points: 141
GE refridgerator with low water pressure
At first it wouldn't give any water at all but makes ice just fine. I thought the water line was frozen but when i took a look at the line beneath the fridge there where no visable problems. I told my wife to press the water button now to see if water would flow through and it did... Then it finally release water.Now it will give water, but with extremely low pressure. Maybe take a whole minute or more to fill an 8oz cup.
I did notice that whoever installed the plastic line from the fridge to the copper line in the wall left the plastic line very long. Would this cause a pressure drop?
sen2two is offline   Reply With Quote
Old 01-13-2012, 12:51 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
filter been changed recently??
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 01-13-2012, 12:58 PM   #3
Rewards Points: 141
Its new. Just bought the house and it had new appliances. I don't have the warranty though.
Old 02-26-2012, 01:47 PM   #4
Rewards Points: 141
I did some searching and found a lot of people had this same problem. Most people saythat there saddle valve was dirty or clogged...
Where and what is a saddle valve?
Old 02-26-2012, 02:23 PM   #5
Signal Guy's Avatar
The saddle valve attaches to, and pierces the water supply line, to supply water to the refrigerator.
When I hooked up mine, the clerk at the home improvement reccomended instalation of a valve in the water line instead of using a saddle valve.
Signal Guy is offline   Reply With Quote
Check valve gimaarob Plumbing 13 10-27-2011 11:13 PM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
New Help With Improving Water Pressure hayhursm Plumbing 1 01-31-2006 07:55 PM
