GE Refridgerator Freezer Meltdown - Appliances - DIY Chatroom Home Improvement Forum
Old 03-28-2012, 09:10 PM   #1
GE Refridgerator Freezer meltdown
The tenant in our rental unit reported the freezer was no colder than the fridge after a electrical blackout. The two conditions may be related or not.
The fridge is a GE Frost Free Top Freezer unit Model # GTS17BBMDRWW / Serial # HD787732. I purchased an online repair manual to see if it was something I could troubleshoot myself and ended up recruiting my dad to test the various connections for continuity and resistance.
I started by cleaning the coils underneath and checking both evaporator and condenser fans were operating properly. Air was circulating in the freezer but it was not getting cold. After all the connections seemed to check out I cleaned the freezer evaporator cover and floor panel and noticed some heat damage.
The plastic piece below the styrofoam block had a heat blister on it. The styrofoam had a meltaway spot, the left lower interior corner had some liner failure and the back of the floor panel had some browned plastic heat damage. I took pics that I will try to attach.
Not sure if this is a problem with the freezer thermostat, the defrost control located in the roof of the fridge or the heater itself. Anyone seen anything like this before and, if so, how did you figure out what needed replacement?
GE Refridgerator Freezer meltdown-03-27-12_1406.jpg   GE Refridgerator Freezer meltdown-03-27-12_1405.jpg   GE Refridgerator Freezer meltdown-03-27-12_1409.jpg   GE Refridgerator Freezer meltdown-03-27-12_1414.jpg
Brywhy is offline   Reply With Quote
Old 03-29-2012, 07:22 AM   #2
Rewards Points: 276
I don't know what caused the problem but I would be motivated to get that refrigerator out of that rental unit before it starts a fire and puts your tenant at risk.
Jim F is offline   Reply With Quote
Old 03-29-2012, 08:07 AM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
looks like the unit got a little hot during a defrost cycle, not a huge deal but if your going to keep the refrig you need to have it checked professionally. That problem however is not the reason for no cooling, so you have 2 problems to deal with.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
Brywhy (04-04-2012)
Old 03-29-2012, 03:19 PM   #4
Thanks hardwareman. I bought a replacement for the condo the next day and brought home the bad one to tinker with. Looks like it is not worth the effort or cost to repair if I can't do it myself.
Old 04-01-2012, 10:49 AM   #5
Sound to me like the defrost timer but be going bad/stuck in defrost. The prolonged defrost cycle would great up the fridge and freezer and also melt that bottom piece. I'd replace the defrost timer and let it come to temp for a few days to make sure it's cooling properly.
jfrotten is offline   Reply With Quote
The Following User Says Thank You to jfrotten For This Useful Post:
Brywhy (04-04-2012)
Baseboard heater meltdown... Master Brian Electrical 2 11-07-2010 02:04 PM
Paint Aisle At Lowe's Best Place To Have Complete Meltdown Hemingway Painting 3 04-04-2009 05:44 PM
