GE Ref. Ice Maker Stopped Making Ice - Appliances - DIY Chatroom Home Improvement Forum
Old 08-08-2011, 03:38 PM   #1
Question
GE ref. ice maker stopped making ice
GE ref. GSS25WGTGBB ice maker, just stopped making ice cubes. Switched the ice maker on and off...the water in door still works and auger to remove ice is ok.
Anything else I can try?
tewksman is offline   Reply With Quote
Old 08-08-2011, 04:16 PM   #2
Check to see if there are two solonoid valves. One for the door
and one for ice maker.
dollarman6 is offline   Reply With Quote
Old 08-08-2011, 04:44 PM   #3
Found the problem with my ice maker. The water going into the freezer tray was frozen solid...so just had to thaw out to get to work again. Freezer was set to cold.
Old 08-09-2011, 07:34 AM   #4
That being the case, your water valve may be leaking by a little to allow
water to stay in the tube
Ice maker stopped working bragl01 Appliances 5 10-30-2015 07:56 AM
Ice Maker Not making Ice BCarmean Appliances 3 08-10-2011 09:16 AM
Ice Maker Stopped Working bsmith95610 Appliances 9 03-21-2011 11:30 AM
Ice maker stopped working. HomerH209 Appliances 3 11-10-2010 08:54 PM
Whirlpool Ice Maker has stopped making ice jpetersen5 Appliances 7 04-13-2008 07:13 PM
