Ge Profile Side By Side Frig With Broken Ice Maker - Appliances - DIY Chatroom Home Improvement Forum
Old 07-26-2007, 10:32 AM   #1
I Have A Ge Profile Refridgerator About 12 Years Old....the Ice Maker Is Not Filling With Water And Is Not Cycling. Could It Be The Water Valve Or The Ice Maker Unit Itself????
BDURR67 is offline   Reply With Quote
Old 08-03-2007, 11:40 AM   #2
Rewards Points: 530
If no cycling, I would suspect the icemaker.
Old 03-14-2008, 12:56 PM   #3
You should do a continuity check on your water valve then you will know if it is the ice maker or the valve.
If you need a new ice maker or fill valve you can get your appliance parts here.
girltech is offline   Reply With Quote
Old 03-15-2008, 09:11 AM   #4
mtm
Rewards Points: 18
My GE refrigerator also stopped making ice. Plus the water dispenser stopped working. I checked the lines running to the refrigerator and they are fine, something broken inside. I knew buying a GE appliance was a mistake, its only 2 years old.
mtm is offline   Reply With Quote
Old 03-17-2008, 11:40 AM   #5
Hi mtm
With your fridge it is newer and is controlled by an electronic board that is located at the back of the fridge.
These boards have been known to fail and cause different problems.
There should be a technician sheet located under the fridge behind the kick plate that will tell you how to test it.
If you require a part you can get your GE appliance parts here.
leaking from under frig when frig w/ice maker was moved forward tzippy Plumbing 1 11-05-2006 01:22 PM
