GE Profile Screw On Valve? - Appliances - DIY Chatroom Home Improvement Forum
Old 07-20-2014, 02:20 PM   #1
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,178
Fridge was getting warm so I was cleaning up the condenser to see if that would help. Since I had the soap out, I gave a little spray around to check for leaks.
In the pic, I found what appears to be a leak at a screw on? valve. Is this a factory type fitting that's coming out lately?
It appears to attach like one of those water pipe take off fittings.
Things are really going down hill these days.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 07-20-2014, 02:34 PM   #2
Rewards Points: 3,782
That's not factory. It's an after market service port, and it's not at all uncommon. Clearly the fridge has been serviced in the past.
Bob Sanders is offline   Reply With Quote
Old 07-20-2014, 02:37 PM   #3
Rewards Points: 13,732
Deleted
Last edited by joecaption; 07-20-2014 at 02:39 PM. Reason: Picture did not come up.
Old 07-20-2014, 03:11 PM   #4
123pugsy's Avatar
Thanks.
I'm gonna give some major flack to someone......
Our refrigeration guy was in there doing work before.
Twice in the last five years on this piece of junk. Why he didn't sweat in a valve, I will have to find out.
So then, are you saying that the factory doesn't provide access valves?
Old 07-20-2014, 04:33 PM   #5
For average residential fridges and window shaker AC's... no. That's why they make after market service ports!
It's not normal to sweat a valve on. That's not really done. It's not solder that's used for refrigeration in the first place. It's all copper brazing. The clamping service ports are used mostly because you don't have to empty, evacuate and recharge with them. Just clamp it on and push the pincher and you have instant access. To braze a new valve on you actually have to open the system up... which costs A LOT extra.
Old 07-20-2014, 06:00 PM   #6
123pugsy's Avatar
In the business in which I work, we refer to the parts in the system as being either sweat or flare. The sweat parts are indeed brazed on with silfoss. I don't take any chances with flare nuts, so my guy should have known I would never accept a screw on part like this.
The time savings is now unrealized because now he will be evacuating the system, brazing on a valve, vacuuming and recharging.
It's always better to pay for one complete job rather than 1/2 jobs several times.
BTW, the compressor was replaced, so the system was already open at the time. Arrrghhh......
The other repair was a burned out cooling fan for the condenser.
Aprilaire 400M Humidifier, cannot open saddle valve! mtlmonk HVAC 1 12-14-2013 05:56 AM
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 07:07 AM
Main Water Shutoff Valve problem obadran Plumbing 16 12-10-2012 11:45 AM
General Help with replacing shut off valve under kitchen sink- Pics included amodoko Plumbing 4 04-02-2012 04:34 PM
