GE Profile Refrigerator Door Won't Stay Closed - Appliances - DIY Chatroom Home Improvement Forum
Old 10-21-2009, 01:20 AM   #1
GE Profile refrigerator door won't stay closed
My 1986 GE Profile refrigerator (side-by-side) door will not stay closed.
I've rearranged all the food items to make sure there's no interference from something in the door or on the shelves, so that's not it.
The freezer door stays closed just fine, but I have to keep a gallon of water braced against the bottom of the refigerator door side to keep it pushed tight - otherwise it hangs near the sealing face, but the door seal just doesn't seem to stick to the box - as if something was pushing the door out about a quarter inch.
It is as if the magnetic door seal has lost all it's magnetism and no longer clings to the box side. Can that happen - Can the seal lose it's magnetism over time? and if so - Is it easy to replace? (& where do you recommend I order one?)
If it's not the seal, could it be that the hinges somehow got out of adjustment? (& if so, is there a procedure for getting the adjustment right - so I don't make it worse?)
Thanking you in advance!
Dan
Motorace is offline   Reply With Quote
Old 10-21-2009, 09:33 AM   #2
The door cam may be broken. At the bottom of the door there are two cams; one attached to the door and the other attached to the hinge. If the one attached to the door is broken all you need is the cam (part number WR2X4901). If the one attached to the hinge is broken you will have to order the hinge kit, which comes with the other cam. You will have to order that by model number because there are a few hinges. Hope this helps!
Last edited by Scuba_Dave; 09-30-2010 at 12:32 PM. Reason: removed adv link in post
applianceman is offline   Reply With Quote
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 10:39 PM
Lights stay on wsixsmith Electrical 19 08-05-2008 07:43 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
Furnace Wont Stay On mccheese82 HVAC 6 12-16-2007 01:11 PM
