Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 09-01-2007, 07:46 AM   #1
Extreme DIY'r Adk's, NY
GE Profile Microwave Buzz No HEat
Can someone certified give me or direct me to safe and proper procedures to check the diode, capacitor and magnetron. I understand and feel safe around electricity and I know how to discharge the cap. Just wondering the proper order and methods so I dont buy one part and have it be three.
It's making a lot of buzzing and no heat by the way. JE1660GB 001 Model
crecore is offline   Reply With Quote
Old 09-01-2007, 11:55 PM   #2
Custom Cabinet Maker
probably cheaper faster better to just buy new one
skymaster is offline   Reply With Quote
Old 09-03-2007, 10:32 PM   #3
...that's helpful. I have a backup nuker from the garage...so speed is not an issue. I like this one and being the extreme DIYer I am, I'd rather fix it for $40 than toss it into our mother earth and buy a new one.
Old 10-03-2007, 07:06 PM   #4
It was a .57 cent diode.
all fixed.
Yeah, cheaper to buy a new one.
Old 10-15-2007, 06:23 PM   #5
mdh
I have the same problem that you described. I had it happen to me about 2 years ago and a service tech changed out the magnatron under warranty since it carries a 5 yr warranty. I can't find the receipt now so I can't get it replaced again under warranty. How can I check the diode?
all fixed.
mdh is offline   Reply With Quote
Old 10-21-2007, 07:00 PM   #6
Knucklez's Avatar
i dunno.. your time is worth $60 per hour... if it took you an hour or more to find that diode then it would haven't been cheaper to toss it and buy a new one.
but if you know what you're look'n for and know what you are doing and fast - then good on ya!!
make us DIY'ers proud
Knucklez
Knucklez is offline   Reply With Quote
Old 10-21-2007, 07:08 PM   #7
The diode is between ground and the coil. If you do not know what you are doing, stop! Especially if the magnetron has failed, the coil (a giant capacitor) can overcharge and be holding around 6000 volts!
Disconnect microwave from power, remove cover. Disconnect all coil wires, short out coil (this can throw a huge spark). Then short each terminal to ground. If it's a 3 pole short every terminal to every other terminal and all three to ground. Diode usually is grounded behind or under coil. Remove coil for access. Remove diode. Use an ohm meter. Diode should read 0 ohms (full continuity) one way, reverse terminals should read infinite resistance. Anything else is a bad diode. fyi, mine was 250 ohms both ways.
good luck and please be careful!
Old 01-10-2008, 10:01 PM   #8
Crecore,
I have the same model and the same issue. I got a new magnetron from GE and it is not the problem, so I need to dig into the diode and the cap.
I had a question, where did you get the replacement diode for .57!!
Rman is offline   Reply With Quote
Old 11-09-2012, 09:59 AM   #9
Thumbs up
My best guess would be Radio Shack. If not there, google it.
gofaster72 is offline   Reply With Quote
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 11:22 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 01:27 PM
heat wont come on with t-stat in auto wahanks HVAC 1 11-22-2006 02:55 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 09:57 PM
heat pump not working kyleGR HVAC 2 05-30-2006 03:35 PM
