#1 |
GE Profile Ice Cube Dispenser Problem
Greetings. I have a GE Profile (Model is TFH 24PR) where the ice dispenser only sends out crushed ice no matter what position the switch is in (cubed/crushed). The water dispenser works fine. Up to this point I have never had an issue with it other than an occasional frozen water line.
Any ideas? The box is roughly 12 years old and I really don't want to replace entire unit. If it is a problem with the switch, is this an easy fix? Thanks. |
#2 | ||
Hi,
http://www.applianceaid.com/frig-dispenser.html#cubes jeff.
Appliance Repair Aid To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. JRAppliance To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Display Modes | |
| Frigidaire water dispenser does not work | waywestside | Appliances | 4 | 09-27-2011 03:20 PM |
| furnace problem | captjack | HVAC | 8 | 11-23-2007 12:15 PM |
| Post-Tension Slab Problem Advice/Help | Mike McBride | Building & Construction | 2 | 01-09-2007 02:51 PM |
| A/C Thermostat Problem | therumblefish | HVAC | 7 | 11-01-2006 09:08 PM |
| Drywall, Mold Problem due to Leaked Water | june03 | Building & Construction | 2 | 10-31-2006 08:24 AM |
