GE Profile Fridge TPS24BPDA BS Running Frozen Water Inside Of Freezer - Appliances - DIY Chatroom Home Improvement Forum
Old 05-22-2010, 08:06 PM   #1
GE Profile Fridge TPS24BPDA BS running frozen water inside of freezer
I've got a GE Profile Fridge TPS24BPDA BS that is suddenly running water out of the ice maker and freezing all over inside of the freezer. I've moved the items in the freezer to another freezer for now. Could the problem be a water valve? Or, is the ice maker in need of replacement? Do any of you have a suggestion on my first step in diagnosing this problem? Thanks.
TimHusker is offline   Reply With Quote
Old 10-17-2010, 08:31 PM   #2
Hello Tim,
Did you ever get an answer to your issue?
I have a GE Profile and it is making long icicles that hang down from the back of the icemaker...
Any thoughts?
Thank you,
Yogi
Yogitrek is offline   Reply With Quote
Old 10-18-2010, 10:14 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,582
most likely the water valve is letting water seep by after it shuts off. If your icicles are small, like an inch or two I'd say the icemaker was just overfilling but if it is running down the back of the freezer it almost has to be the valve.
hardwareman is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Older GE Fridge no Ice WorldOfJohnboy Appliances 3 09-10-2009 08:39 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Help! hot water won't stop running despite faucet changes. nodak_luke Plumbing 4 12-14-2007 06:38 PM
