-   -   GE Profile Double Oven, Need Help! (http://www.diychatroom.com/f47/ge-profile-double-oven-need-help-55640/)
lighting lady 10-21-2009 09:59 AM
I have a Beautiful GE Profile double oven. I was recently making chicken wings that cook in a bit of marinade. When It was time to take them out some of the marinade spilt out of the pan and ran between the glass panel of the door and the oven wall of the door. Now I have this big drip mark that can be seen from the outside it looks terrible! I've tried to clean it already in hopes that the heat would help dissolve it, but it didn't work. Any ideas would certainly be appreciated! What a way to ruin the looks of such a great appliance.:help:
ibzbro 10-29-2009 08:12 PM
You have to take apart the door and clean it... if your lucky you can clean away the mess... if not you have to replace the middle glass assembly. I would first take it apart and see if you can clean it with some sprayaway glass cleaner that hopefully will do the trick. good luck:thumbsup:
Jacques 11-04-2009 07:18 AM
to take door apart-remove door and place on kitchen table front side down...common problem usually caused by spill overs not wiped up before door is closed -thus the gook runs down behind the windows.
