Ge Profile Double Door Bottom Freezer - Appliances - DIY Chatroom Home Improvement Forum
Old 01-17-2011, 07:32 AM   #1
Ge profile double door bottom freezer
why is it not cooling properly? I tried unplugging it , adjusting temp, cleaning bottom with a vac. But is not holding temp. top is 66/ freezer is 22
dukas is offline   Reply With Quote
Old 01-17-2011, 07:44 AM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
There is a little fan in the back of the freezer (?) compartment that is not working. call a repairman or change the part out yourself.
Andy.
AndyGump is offline   Reply With Quote
Old 01-17-2011, 10:36 AM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
Andy.
why would you give him advice like that when there is no way you can possibly know what the problem is, how do you know it is not a defrost problem, a condenser fan motor, cold control, damper control or any number of things. If he goes out and buys a fan motor and that does not fix it, then what?? More than likely I'd say he has a defrost problem but he needs to give us a little more to go on then just "it is not cooling".
hardwareman is offline   Reply With Quote
Old 01-17-2011, 11:35 AM   #4
AndyGump's Avatar
Rewards Points: 688
One reason is past personal experience, perhaps IO should have put in there a the word probably or even a "in my opinion".
I made the assumption that the OP is not stupid and would probably check it out on his own.
I also think most people are familiar with the old adage that "free advice is worth what you pay for it".
Andy.
Old 01-17-2011, 12:09 PM   #5
#1 HAWKEYE FAN
Thumbs down
Andy.
that kinda defeats the whole purpose of this forum doesn't it?
Old 01-17-2011, 03:39 PM   #6
AndyGump's Avatar
Rewards Points: 688
Perhaps, but it is still kind of fun at times.
Andy.
Double switch wiring rockclimber Electrical 18 03-18-2012 10:13 PM
GE Profile Fridge TPS24BPDA BS running frozen water inside of freezer TimHusker Appliances 2 10-18-2010 09:14 PM
GE Profile Double Oven, Need Help! lighting lady Appliances 2 11-04-2009 07:18 AM
Freezer odors - coming from blower/fan Richo Appliances 3 05-27-2009 05:26 PM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 09:55 AM
