GE Oven Coming On By Itself - Appliances - DIY Chatroom Home Improvement Forum
Old 07-31-2009, 02:44 PM   #1
GE oven coming on by itself
Hi, I just had a bad ignitor in my oven and I just got done replacing it. The good new is that the ignitor works now so my oven is now working. The bad news is there is NO play in the oven knob between 'off' and 'on'. It will cause my oven to come on by itself. So basically I have to put alot of pressure on the knob turning it off until I hear the "click" of the ignitor turning off. But sometimes I'll be standing by and hear the "click" of the ignitor turning on when I never even touched the knob and it's still in the off position. This is no doubt what caused my previous ignitor to go bad. Is there a way I can adjust the play between on and off on the knob so it won't come on until I actually press and turn the knob? Thanks for your help.
Super33 is offline   Reply With Quote
Old 07-31-2009, 10:52 PM   #2
long island, NY
I can't contribute a solution... I just want to confirm that only the ignitor is going on randomly... not the gas, right? If the gas IS going on with the ignitor, it would make me very nervous to have an gas oven with a mind of its own. I would shut off the gas from the wall until the oven was fixed.
diy'er on LI is offline   Reply With Quote
Old 08-01-2009, 09:57 AM   #3
Yes, the ignitor is coming on, when that comes on the natural order of the oven is to turn on the gas thus igniting the flame. So the oven is coming on by itself. I can hear the switch in the knob clicking the ignitor on. I can apply pressure on the knob towards the off position and hear the click turning it off. But then after I let go of the knob I can hear a click again after a few seconds and the ignitor comes back on. It seems to me that the knob has absolutely no play between on and off. I turn off the power to the oven when not in use so the ignitor won't turn the oven on by itself. My question is, how can I adjust the knob or the switch behind the knob to give me a bit more room in the off position?
Old 08-22-2009, 08:15 AM   #4
now you know why appl techs get the big bucks-woulda seen that at initial inspection-otherwise the famous "it never did that before"...to answer your Q, you can't adust it. you have a dangerous situation and i urge you to shut down gas/electrical untill corrected.
Jacques is offline   Reply With Quote
Old 08-22-2009, 08:18 AM   #5
Electrical Contractor
kbsparky's Avatar
Sounds like a bad part there. Check with the manufacturer, maybe it has been recalled? Ovens turning themselves on is a dangerous thing!
-KB
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 02:19 PM
Oven - junction box in cabinet DIYGST Electrical 5 11-13-2008 03:23 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
