GE Oven Clock Control Panel - Appliances - DIY Chatroom Home Improvement Forum
Old 01-16-2014, 09:41 PM   #1
Question
GE oven Clock Control Panel
The bake element of my GE oven (Model JSP26G0V1WH) apparently shorted and burned out and the display of the ECC (Electronic Clock Control) is now blank (no LED's lit). I replaced the bake element but the ECC is still blank and pressing the buttons does nothing. I know there is power to the appliance because all 4 stove-top elements operate normally.
I need some direction in trouble shooting this. Not sure if there are any fuses/breakers in the oven that I can check. Is it possible the ECC is fried?
jaybob1234@att.net
jaybob1234 is offline   Reply With Quote
Old 01-16-2014, 11:40 PM   #2
Rewards Points: 6,652
It is all solid state. The problem is, that once you replace one board, then you end up later on replacing the other board. Most of these boards run anywhere from $120-300, depending on the oven.
You can go to http://www.repairclinc.com and enter you make & model of oven, and see what the parts will cost you.
After I had a second board go out on my Whirlpool range, after I replaced the first one, it was cheaper to just buy a whole new range, then keep letting it nickle and dime me to death.
The Following 2 Users Say Thank You to gregzoll For This Useful Post:
jaybob1234 (02-03-2014), Startingover (02-03-2014)
Old 02-03-2014, 09:59 PM   #3
Thank you for your advice. I will probably do as you said and just get a new range.
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 08:15 PM
Use panel as a junction box? LynnX Electrical 18 01-05-2014 06:56 PM
Troubleshooting Damper Motors & Control Panel ARB HVAC 2 12-17-2012 07:46 AM
distribution panel amperage rating tom31415926 Electrical 10 08-26-2012 05:09 PM
Subpanel next to Main panel wired the same in 1990 Uncle Wayne Electrical 3 01-20-2011 01:43 AM
