Ge Oven - Appliances - DIY Chatroom Home Improvement Forum
Old 11-22-2010, 02:03 AM   #1
Ge oven
I need your help. I have a ge wall oven model jgrp20wej1ww. When i turn the oven on the fan makes a loud noise the whole time the oven is on .it started about a month ago the oven is 5 years old.is there a way to oil it or clean it or is there an air intake screen to clean. This is driving me crazy. Other then that the oven works fine. Someone please help the noise is so loud i can't even talk in the kitchen.
Thank you
bonnie
BUDDYSHADOW is offline   Reply With Quote
Old 11-22-2010, 09:27 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
your fan motor is a cooling fan motor for the control panel, very important it operate correctly. Yours is probably going bad and needs replacing. You'll probably have to pull the whole unit out to get to the fan. Good luck
hardwareman is offline   Reply With Quote
Old 11-23-2010, 03:20 AM   #3
is this something my husband can do. He is pretty handy. He is the one that put the oven in when we remodeled the kitchen. I want to thank you for all your help. Is this part very expensive. If i am looking at the correct part. Is it called the fan asm - conrol upr. Am i correct on this.
Old 11-23-2010, 03:22 AM   #4
Old 11-23-2010, 03:23 AM   #5
Hardwareman
Old 11-23-2010, 07:57 AM   #6
#1 HAWKEYE FAN
it is fairly simple, pull the oven out, remove the top cover and he'll see what to do from there.
Old 11-23-2010, 01:16 PM   #7
Thank you very much for your help. I will let my husband know.
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 02:19 PM
Oven Blew Up at Connector with Element cynthiap Appliances 6 10-31-2015 09:48 AM
Oven Install and Replacement- Dacor $400 CostcoMan Appliances 1 05-24-2010 06:02 AM
Gas oven problems gregsmy Appliances 1 12-03-2009 05:55 AM
Counter top trim to fit with slide in oven bhagey Appliances 1 07-17-2009 08:32 AM
