GE Nautilus Dishwasher Stopped Mid-cycle - Solution Included - Appliances - DIY Chatroom Home Improvement Forum
Old 03-20-2011, 11:14 AM   #1
PatrickGSR94's Avatar
Rewards Points: 87
GE Nautilus dishwasher stopped mid-cycle - solution included
So I just put my dishwasher back in the other night after having it out for awhile while tiling the kitchen. I got it back in, loaded it up, and washed some dishes Friday night. Saturday I woke up to find the dishwasher had stopped mid-cycle (right at the start of rinsing) with water standing in the bottom of the tub.
I searched around, found this website with a parts diagram: http://www.appliancepartspros.com/pa...odel_id=209307 and decided to take the door apart. I found that part number 805 and 806 (switch leaf) had broken off from the door face. There was a little plastic "stud" holding a screw which held the switch leaf, and the stud had broken off. The switch leaf presses on 2 button switches when you latch the door, allowing the dishwasher to run.
http://img.photobucket.com/albums/v3...r/IMG_6944.jpg
So instead of buying a new front face for $40+ I decided to just drill a hole and use a screw to hold the switch leaf in place. I used 2 washers, lock washer, and a nut to hold the screw in place, then 2 more nuts, 2 washers, and a lock washer to hold the switch leaf in the right place on the screw.
http://img.photobucket.com/albums/v3...r/IMG_6945.jpg
There is a screw head visible on the outside of the dishwasher, but it's really not that noticeable. When you're short on cash, a $0 repair is always better than a $40+ repair.
http://img.photobucket.com/albums/v3...r/IMG_6947.jpg
Hope this might help anyone that searches for a similar problem. Apparently this is rather common as I found someone with a similar issue here: http://forum.appliancepartspros.com/...ont-start.html
PatrickGSR94 is offline   Reply With Quote
conversion of portable dishwasher to stationary one grimsbyman Plumbing 15 02-13-2014 10:45 AM
dishwasher stopped mid cycle joetab24 Appliances 1 10-02-2010 07:51 PM
Dishwasher Has Poor Wash Cycle skittlzski Appliances 2 05-20-2009 10:44 AM
Dishwasher has water in bottom at the end of cycle judyll Appliances 6 05-10-2009 11:14 AM
