GE Icemaker - Appliances - DIY Chatroom Home Improvement Forum
Old 03-07-2012, 10:12 PM   #1
D23
GE icemaker
Model GFSS6KKYASS ice maker no longer makes ice. Water line is ok, still getting great flow of water thru door. Did not change temp in freezer. Any ideas?
D23 is offline   Reply With Quote
Old 03-08-2012, 01:01 AM   #2
Rewards Points: 13,468
http://www.acmehowto.com/howto/appli...agicemaker.php
This may help figure it out.
Old 03-09-2012, 09:21 AM   #3
There are two separate water solenoids for ice maker and water dispenser. Just because your water dispenser works doesn't mean the ice side does. You need to replace either the water solenoid for not opening when it should or replace the ice maker for not calling for water when it should.
jfrotten is offline   Reply With Quote
Can I remove wire arm from icemaker boandbob Appliances 4 12-12-2011 05:04 AM
Icemaker Diagnosis Help SPS-1 Appliances 3 11-12-2011 09:32 AM
How do you hook up a water line for in icemaker? kennykenny Plumbing 8 06-22-2010 03:23 PM
Kenmore icemaker problem bikercraig Appliances 1 08-12-2009 08:12 PM
whirlpool icemaker problem pbl1962 Appliances 2 12-26-2007 02:07 PM
