GE Gas Dryer Only Runs When 'Start Knob' Is Held. - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-15-2012, 10:11 PM   #16
Rewards Points: 83
GE Gas Dryer only runs when 'Start Knob' is held.
Originally Posted by Missouri Bound View Post
I do not think it would run if the idler switch was open..holding the start switch would not override it. (IMO)
Yes it would, it would just run on start windngs not run windings. Did you look at the wiring Diagram? The idler sw would be about the same electrically as the centrifugal sw not switching states.
Protocol. is offline   Reply With Quote
The Following User Says Thank You to Protocol. For This Useful Post:
Missouri Bound (08-15-2012)
Old 08-17-2012, 07:49 AM   #17
If the start windings stayed in ckt it would smoke up...at start up the windings are in parallel, the cent sw then immediatly drops the start winding out of the ckt and connects the run winding in series with the timer contacts, which are in series with the belt sw. if the belt sw [idler controled] is open for some reason, and you let go of start sw, motor will stop and cent sw will reset- as you've lost a complete ckt.
Jacques is offline   Reply With Quote
dryer runs backwards Boz Appliances 17 12-18-2015 04:51 PM
Clothes Dryer Ventalation crankbait09 HVAC 6 07-03-2012 07:24 PM
Washer & Dryer Holiday Fun BRIANisMEisWE Appliances 8 12-24-2011 03:41 AM
Problems with Whirlpool Dryer Hookup! Help! maryrgrimm Appliances 1 04-07-2010 08:42 AM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 05:26 PM
