Ge Gas Dryer - Appliances - DIY Chatroom Home Improvement Forum
Old 06-21-2012, 09:05 AM   #1
Post
ge gas dryer
the ignitor doesnt come on. I checked the 2 outlet thermostats and both closed.the inlet thermostat is really hard to get to and didnt check it. the reading on ignitor is 145 ohms. is that a good reading, so thats not burned open.I cant check voltage to ignitor because drum will turn and it is not in tact because front of dryer is off and holds drum in place
any ideas appreciated
thanks Paul
paulat120 is offline   Reply With Quote
Old 06-21-2012, 09:16 AM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
The resistance should be less than 60 ohms but it is brand specific. Most likely a bad ignitor.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
The Following User Says Thank You to Clutchcargo For This Useful Post:
paulat120 (06-21-2012)
Old 06-21-2012, 10:19 AM   #3
DIY or die !
Rewards Points: 77
you need to verify you have juice @ the ignitor. pull the front off, unhook the belt from the pulley, pull the drum out. Check voltage to ignitor.
Check back.
lewisthepilgrim is offline   Reply With Quote
The Following User Says Thank You to lewisthepilgrim For This Useful Post:
Old 06-21-2012, 12:40 PM   #4
ge gas dryer
I have 23 volts at plug to ignitor and it doesnt glow. it also reads 145 ohms any help
thanks
Paul
Old 06-21-2012, 01:06 PM   #5
Check back.
i have 23 volts at plug to ignitor
thanks Paul
Old 06-21-2012, 03:06 PM   #6
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
find the thermal fuse and check it, I'm pretty sure you'll find its bad.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 01:10 PM
DRYER HELP or Bigger Problem? SitEatChat Electrical 19 05-05-2012 01:12 AM
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 11:00 AM
Help with Electric 240v for a Dryer Sunshine807 Electrical 17 10-21-2011 10:35 AM
Dryer exhaust duct not connected inside dryer frankrizzo Appliances 4 02-09-2010 08:47 PM
