Ge Gas Dryer - Appliances - DIY Chatroom Home Improvement Forum
Old 06-20-2012, 05:22 PM   #1
Question
ge gas dryer
no heat
my flame sensor reads open when cold. what is sequence op operation.should it start out open then close when flame is detected or is it defective. If flame sensor should be closed can I jump it out for testing or does it open when a flame is detected
is 145 ohm ok for reading of ignitor and can the ignitor be touched by hand without ruining it.
thanks paul
paulat120 is offline   Reply With Quote
Old 06-20-2012, 06:03 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,596
flame sensor should read open, the ignitor will come on and glow, after a few seconds it gets hot enough to close the contacts on the sensor. Sensor closes, flame comes on. Do not jumper it.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
paulat120 (06-21-2012)
Old 06-22-2012, 10:57 PM   #3
Rewards Points: 83
Shouldn't touch the hot surface ignitor. The oils from your hands can damage the ignitor.
Protocol. is offline   Reply With Quote
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 02:10 PM
DRYER HELP or Bigger Problem? SitEatChat Electrical 19 05-05-2012 02:12 AM
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 12:00 PM
Help with Electric 240v for a Dryer Sunshine807 Electrical 17 10-21-2011 11:35 AM
Electric Dryer not turning on c.abrams Electrical 3 01-09-2011 07:18 PM
