GE Front Loader Washer Leaking Out Front Bottom - Appliances - DIY Chatroom Home Improvement Forum
Old 09-03-2013, 09:19 AM   #1
Rewards Points: 175
Question
GE front loader washer leaking out front bottom
For some reason my front load GE washer is leaking out the front..sometimes a lot, sometimes only a little, it's odd.
I think it's a few years old, as it came with the house we just purchased. My guess after tracing it a bit is possibly the gasket? Since those seem to be common failures, is that the route I should go first, or just get a plumber in to knock it out and fix it?
vivithemage is offline   Reply With Quote
Old 09-03-2013, 03:06 PM   #2
K&B Designer
Live_Oak's Avatar
Yes, replace the gasket. That's assuming that you've inspected the gasket for foreign bodies, nicks & cuts, and for plasticity? Another suspect is the detergent tray dispenser. If you're using powdered detergent, you can get some splashback unless you have the powder insert in the pull out dispenser. Those two issues are easily DIYable. If you can't DIY, the correct tradesman would be an appliance repair person, not a plumber. Avoid A&E Factory Service if you do have to call a repair person.
Live_Oak is offline   Reply With Quote
Old 09-03-2013, 03:22 PM   #3
Rewards Points: 175
Yeah, I did just watch a few GE videos, it says you should keep the gasket clean, so I might check that and have my GF check it before she does a load.
What portions of the detergent tray fails?
LG Front load washer LarsFromMars Appliances 13 07-16-2013 11:04 AM
Bosch Dishwasher leaking along bottom seal of door mtbdudex Appliances 14 10-13-2012 08:49 AM
Front load Amana washer leaking from inside of door! Stephenby Appliances 4 06-10-2012 06:38 PM
Fixing a gap at the bottom of the front entrance door? imola ghost Building & Construction 1 09-01-2010 07:50 PM
Water leaking in garage everytime we use washer! Please Help shigyrl217 Plumbing 3 12-16-2007 07:03 PM
