Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 04-24-2007, 12:25 AM   #1
Default GE fridge evaporator fan change and still not working
I have a GE fridge with the freezer on top. I changed the evaporator fan motor because it was not working. I put the new motor in and the fan is still not working. Is there another part that could be bad that makes the fan work? I am so frustrated. I was sure it was the evaporator fan. The fride is going into defrost and I see the defrost heater working and the freezer is working but the fridge is not cold enough. Any help would be greatly appreciated. Here is the model number, GTS22LB
Thanks Trish
Trish is offline   Reply With Quote
Old 03-28-2008, 02:38 PM   #2
Your fridge has an electronic control board that is located at the back of the fridge that controls the operation of the fan.
The control board (mother board) has likely failed and will have to be replaced.
Here is a good place to get your Appliance parts.
girltech is offline   Reply With Quote
Old 03-30-2008, 03:47 PM   #3
jeff1's Avatar
Hi all,
GTS22LB
That is part of a full model#.
A good possibility
Main control board
jeff.
Appliance Repair Aid
www.applianceaid.com
JRAppliance
www.jrappliance.ca
jeff1 is offline   Reply With Quote
More On This Topic
Okay so now we are back and we are ready to do part three of the quiche and it really is so quick because you can see there are 24 of them already done. I cut the puff pastry crust, didn't even need to make that, just defrosted it right out of the... Read More »
How to Build a Pizza
How to Build a Pizza by Expert Village
Hi, this is Richard Buccola here in New York City and on behalf of Expert Village, today I'm going to show you how to take all of that frozen pasta sauce that you have your freezer and show you different ways to make some fast inexpensive pizza where you... Read More »
Hi I'm Marieve Herington here for Expert Village. And today we're doing easy, quick holiday entertaining. So, I don't know about you, but I think the whole holiday appetizers right out of the box nice and freezer burned, yeah that's really over done for... Read More »
Layer an Apple Tart
Layer an Apple Tart by Expert Village
All right, now I'm just layering up the tart. This pastry dough, I didn't have to explain it because I didn't make it. I just bought it. It's puff pastry which I defrosted overnight in the fridge and I have just rolled it out on parchment paper which we... Read More »
In this clip we're going to talk about the proper way to remove and replace an electronic cooling fan. In this step we're going to go over the proper service procedure for removal of the actual cooling fan assembly. And we're going to go over the test... Read More »
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
