GE Electric Dryer Won't Shut Off In Auto/high Heat Mode - Appliances - DIY Chatroom Home Improvement Forum
Old 02-15-2008, 02:23 PM   #1
GE Electric Dryer won't shut off in auto/high heat mode
I have a GE electric dryer, about 12 years old, and it works in the timer mode (medium heat), but it won't shut off if in the automatic mode (high heat). Can anyone help me on what the problem is and how to fix it? I replaced the timer and it didn't fix the problem.
Thanks for all your help.
jktbnelson is offline   Reply With Quote
Old 02-15-2008, 02:58 PM   #2
Is the timer moving at all?
Do you have the model number of your dryer?
It is most like the operating thermostat that is not working.
girltech is offline   Reply With Quote
Old 02-15-2008, 03:30 PM   #3
Will post model #
Girltech,
In the auto/high heat mode, the timer moves only about 10% of the time. In the timed/med heat mode, it works fine.
Thanks for the info. I will get home and check out the model# and get it posted asap.
If it is the operating thermostat, I just hope I can find my way around the inside of the dryer to replace it.
Thanks again.
Old 02-16-2008, 04:42 PM   #4
The model # is DVLR233ET1WW. Any suggestions on the problem and how to fix it? Thanks again for all your help!
Old 02-18-2008, 01:20 PM   #5
There seem to be something wrong with your model number as I can bring a picture up. Can you check it for me?
Does the timer move around to the off position but just not shutting off?
Old 02-18-2008, 04:56 PM   #6
Model# DVLR 223 ET1WW
DVLR223ET1WW is the model # and the serial # is SS910903G (I double checked it). The timer knob does not move after I set it (in the high heat/auto mode). It does move in the timed heat (medium mode). Thanks for any help.
Old 02-19-2008, 09:55 AM   #7
You will need to replace the operating thermostat.
It is locate in the blower housing. The temperature rating on the thermostat will be L135-15F.
Here is a great place to get appliance parts.
Old 01-15-2011, 08:39 PM   #8
PROBLEM: Dryer won't stop running.
Description: I have a GE electric dryer. It works in the timer mode (no heat), but it won't shut off if in the automatic/high/medium mode.
Should I get an operating thermostat to try to fix?
Model#DCLR333ET1WW
SERIAL#VT121256G
I went to the below site, but it has two thermostats. I don't know which one to get. Is this hard to replace?
http://www.easyapplianceparts.com/Mo...E&Type=&Mark=3
Rachel
rnt10 is offline   Reply With Quote
Electric Dryer wiring/plug question SpaceCrawler Electrical 6 08-26-2008 05:33 PM
Whirlpool electric dryer won't heat jpplumber Appliances 5 01-13-2008 11:21 PM
Dryer won't shut off but has no heat Keyo77 Appliances 8 10-07-2007 03:42 AM
Problem with ELECTRIC DRYER plugs SpaceCrawler Appliances 6 06-03-2007 11:21 AM
Convert from electric heat to oil/propane? Badfish740 HVAC 7 05-15-2007 12:17 PM
