GE Dryer Venting Issues - Appliances - DIY Chatroom Home Improvement Forum
Old 01-01-2008, 03:16 PM   #1
newer than a newbie...
Rewards Points: 87
GE Dryer venting issues
Hi There.
I have a dryer that has been in place for a year now, but I actually want to vent it correctly as opposed to having a long, flexible vent stretch from the back and squeeze over top and to the left side where it can vent to the outside (it's ugly)
However, I have an issue in that the typical side vent (it is a GE vent that has a pop out side vent on the left rear) has a 10" wall that will make it difficult. Instead, I would like to cut a place on the left side (closer to the middle left) so that the vent can directly be there to be directed out.
Questions I have:
1) Can I do this easily?
2) How can I do this to make a perfect circle? I know there are those metal cutters, but I've never used these - should I use a drill?
3) If I have to cut the metal cylindrical ducts, should I use a saw of some kind or the metal cutters?
I have attached a picture to give you an idea of my situation.
mcvane is offline   Reply With Quote
Old 01-01-2008, 09:35 PM   #2
remodeling pro
If the dryer does not have "factory knockouts" in the sides for this, then side venting is probably not an option because of the mechanical layout inside of the case. This is usually more of an issue on gas dryers than electric, where the gas piping and hot air plenum design often limits vent options to rear or only one side. Check the installation manuel for options on your model (usually viewable on line if you don't have it). If it has a side knockout as your sketch seems to indicate, I doubt if you could bring the exit hole that far farward without interference from some internal component. As for cutting the hole, tape the area off with duct tape to protect the finsh, and use a jig saw with a metal cutting blade, or a four inch hole saw (harder to control). Since this machine is only a year old, keep in mind that doing this will instantly void any remaining warranty, whether the problem is a result of your modification or not (factories just love free easy out excuses)
troubleseeker is offline   Reply With Quote
Old 01-01-2008, 09:57 PM   #3
Rewards Points: 87
non-descriptive manual
I have the original manual (I probably should've said) but all they say is a mini-blurb about punching out the perforated hole in the side and running venting to it - although they have 3 or 4 diagrams, they totally make no sense to me even though I look over them several times! They are written not to educate at all!
Anyways, thanks for your suggestion. My drawing actually only needs me to move the hole maybe 5-6 inches from the perforated spot...I may take the risk.
Old 01-01-2008, 10:30 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,726
Ayuh,........
I suggest that you take a panel Off,+ LOOK before you start cutting..........
Old 01-01-2008, 10:49 PM   #5
Union HVAC Tech.
There is a definite reason for the hole being where it is and I am sure it has to do with the mechanics of the dryer.
bigMikeB is offline   Reply With Quote
Electric Dryer wiring/plug question SpaceCrawler Electrical 6 08-26-2008 04:33 PM
Venting bathroom through dryer? phantoz HVAC 3 09-08-2007 11:53 AM
Venting Dryer aokss Remodeling 3 04-09-2007 04:12 PM
Venting Dryer Through Roof Thirdeye General DIY Discussions 1 03-04-2007 11:06 AM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 09:16 PM
