-   -   GE Dryer making loud scraping noise (http://www.diychatroom.com/f47/ge-dryer-making-loud-scraping-noise-14837/)
mcates 12-28-2007 03:04 AM
When I turn on the dryer it makes a scraping or grinding noise. There is nothing in the belt, the drum glides are good and there is nothing caught in the trap.
rjordan392 12-28-2007 09:29 AM
It may be the bearing that the back part of the dryer drum spins on. This happen to me many years ago. I do not recall the details in replacing it but I believe I had to roll the dryer on its face and then remove the back panel to get to a mounting bracket for the drum. After this mounting bracket was removed, the bearing was exposed and replaced. Back then, the bearing appeared to be made of leather material. This was for a General Electric dryer.
mcates 12-28-2007 01:58 PM
I have fixed the noise...now it smells like something is burning....
rjordan392 12-28-2007 02:44 PM
Unfix what you just did. If something else goes wrong while making adjustments to the original problem, then it may be time for a dryer mechanic. You have to weigh the expense of his labor and cost of materials against a new dryer. I am not a dryer mechanic but I am handy. What did you do to fix the original problem?
girltech 03-05-2008 03:05 PM
Did you find out what was making the scrapping noise?
If you need parts for your dryer here is a good place to get appliance parts.
Have your model number ready.
