GE Dryer Drum Glides - Appliances - DIY Chatroom Home Improvement Forum
Old 11-22-2011, 12:49 PM   #1
mem
Rewards Points: 156
GE dryer Model DPSQ495ET5WW. I am replacing front drum bearing-WE3M26-and glides. I have two green glides-WE1M481-and two white ones-WE1M504. The drum bearing is worn paper thin in spots and the old glides are completely disintegrated so I can't tell where each color should be located on the drum bearing. Anybody know? I am replacing the rear bearing-WE25M40-as well.
mem is offline   Reply With Quote
Old 11-22-2011, 05:50 PM   #2
BobRivet's Avatar
When I replaced mine last month, I recall that all four were on the top portion of the drum and as long as you have a white, then green, then white then green (alternating - I don't believe it matters which color you start with), you should be fine.
It was amazing the difference.
BobRivet is offline   Reply With Quote
Old 11-22-2011, 06:42 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,582
green ones at the top , whites ones on the side
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
mem (11-22-2011)
Old 11-22-2011, 06:49 PM   #4
mem
Rewards Points: 156
Thanks for the info Bob, but I went a different route. Since I posted I was able to locate this image from a link to applianceaid.com by forum member jeff1--he's an appliance guy.
As you can see, the white glides go outboard of the green ones. Thought it made good sense so I went with it. And, yes, what a difference it makes. Not fun using a cloths line in Ohio, in November!
Old 11-22-2011, 08:42 PM   #5
#1 HAWKEYE FAN
not that it matters much but them white ones should be a little further down
Old 11-23-2011, 10:56 AM   #6
mem
Rewards Points: 156
Not sure what you mean. There are only four mounting locations on the drum bearing for the glides. It really offers no choice for placement other than which color goes where.
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 02:10 PM
Help with Electric 240v for a Dryer Sunshine807 Electrical 17 10-21-2011 11:35 AM
Dryer Drum Roller Siezed SPS-1 Appliances 4 06-06-2011 01:19 PM
Maytag dryer drum won't start when hot dmdonnay Appliances 2 01-10-2011 10:00 PM
Frididaire dryer glides sflamedic Appliances 3 03-26-2008 11:57 PM
