GE Dryer Does Not Shut Off In Any Mode - Appliances - DIY Chatroom Home Improvement Forum
Old 01-27-2009, 08:51 PM   #1
GE Dryer does not shut off in any mode
I have a GE Dryer model# DBSR453EB0WW which is about five years old. The other night I noticed it had been running non-stop for about four hours - and the vent tube was cool. I turned it off and let it sit overnight and through the next day. In the evening I turned it on and it seemed to work, heat came on, etc. When I ran it that evening on automatic mode (moisture sensing) it didn't turn off even though the clothes were dry. The vent tube was warm (as expected) and exhaust air outside of the house was moving as expected indicating no blockages. If I run the dryer in straight timer mode it counts down to around 20 minutes and stays there running until I shut it off.
Is this a thermostat problem? If so which one? I believe this dryer has two maybe three of them.
brogrimm is offline   Reply With Quote
Old 01-27-2009, 10:17 PM   #2
If you run it on the timed cycle and it won"t shut off, it has a bad timer...If it won"t shut off on the automatic cycle that"s a different deal....
GE JIM is offline   Reply With Quote
Old 01-29-2009, 09:01 PM   #3
That's what's strange to me. It won't shut off in automatic cycle; and in regular timed mode it essentially won't shut off. I set the timer for 30 minutes last night and an hour later it was still running showing just under 20 on the dial. And the clothes were perfectly dry.
Old 01-29-2009, 10:27 PM   #4
It probably has a bad gear in the timer..Maybe a missing tooth on the gear right around the 20 minute mark...You would need to check for 120 volts at the timer motor to prove it....
Old 01-30-2009, 08:11 PM   #5
I hadn't thought of that. Thanks for the tip!
Tags
dryer , electric
GE Electric Dryer won't shut off in auto/high heat mode jktbnelson Appliances 7 01-15-2011 08:39 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 05:26 PM
Dryer Pony Problem. Hobb3s Electrical 17 09-30-2008 09:16 PM
Dryer doesn't shut off kiddo Appliances 3 01-24-2008 10:58 AM
Dryer won't shut off but has no heat Keyo77 Appliances 8 10-07-2007 03:42 AM
