-   -   GE Dishwasher - removing lower spray arm (http://www.diychatroom.com/f47/ge-dishwasher-removing-lower-spray-arm-126546/)
handeman 12-13-2011 06:05 PM
4 Attachment(s)
Hi everyone,
Lately my GE Dishwasher (Model GSD5211P00BB - see picture #1 below) hasn't been properly washing dishes and has been leaving a bit of water on the bottom.
I tried taking it apart tonight, but am stuck. I unscrewed the two screws holding the basket in place at the back (which appearing to have some gunk from our liquid detergent and some mold on it - see picture #2 on the right side), but the basket is attached to the lower spray arm piece.
I've looked up how to remove the lower spray arm with no success. There doesn't appear to be a screw or piece holding it in place. Some sources say to pull up while twisting counterclockwise which doesn't appear to do anything (I don't want to break the plastic, and if i pull harder, I worry I will). Others say to insert a screwdriver at the bottom, but I don't see a spot to do so.
Take a look at pictures 3 and 4 - there looks to be a plastic piece out of place with a yellow rubber piece sticking out. I can't really move these around or try to fix them without getting the spray arm off.
Any help would be appreciated!
Thanks,
H
hardwareman 12-13-2011 07:00 PM
lower spray arm on GE came off one of two ways depending on age. Older style, unscrew the tower nozzle that comes out of the spray arm. newer style, lift up while turning counter clockwise( may take more than a little upward force.
handeman 12-13-2011 07:12 PM
I don't think it's the older style, as you can see from picture #2, there's no spot to screw in the tower nozzle.
I've tried several times lifting and turning the spray arm, and if I do it anymore I'm going to break the plastic. It just seems to spin when I do that....any other tips or ideas?
Jacques 12-14-2011 06:30 AM
That's how the spray arm assb' comes off- on your d/w=lift and turn ccw. looks like your using all n one tablets. maybe you'll find the plastic wrappers are down in the sump- blocking the screen that's down there.
jfrotten 12-14-2011 10:03 AM
Underneath the spray arm in the front is a screw. Remove it. Then stick your head all of the way in the dishwasher. Behind the spray arm there is a plastic tab that you have to pull out prior to lifting up on the spray arm. Be careful though, if you pull too hard it will snap off. This tab is ultimately what is holding the arm in place.
hardwareman 12-14-2011 07:21 PM
can not find your model # in the parts look up..... strange
handeman 12-14-2011 07:56 PM
That was it - thanks JFrotten! The screw had already come loose on its own. I just had to get a screwdriver in the tab at the back and the arm slipped right off.
I took apart the rest of the bottom parts and cleaned out all the gunk. I couldn't find any obvious clogs or anything though. We'll give it another try and see what happens...
