GE dishwasher not draining
Yes. Sounds like a pump. You should be able to do it yourself. Kinda tricky but not a huge job. Check the drain line between pump and your sink drain first. It may be clogged. You are looking for a plastic or rubber hose connected to your sink drain. The other end of this hose plugs into the DW pump. Shut power off first and Disconnect this hose where it connects to pump at bottom of DW. Check this hose to make sure it is clear. Then you can get a good look at pump and you should see how to remove it. Usually a clamp on each end of pump and maybe 1 or 2 screws holding it in bracket. 2 wires connected to it. Remember how it goes. Remove it. Get model numbers. Try to spin it by hand and reinstall. Test to see if it works now. Leave it installed until new one arrives. I ordered a few from amazon. Just make sure you get the part numbers right.
Dan101
Owner
J.& D. Remodeling
Chicago, IL
