Gasoline Left In Snowthrower - Appliances - DIY Chatroom Home Improvement Forum
Old 03-16-2012, 09:06 PM   #1
Gasoline left in snowthrower
I still have some gasoline left in my snowthrower. Should I burn it off, or can I let it stay in the machine over the summer. Thanks
elginman is offline   Reply With Quote
Old 03-16-2012, 09:09 PM   #2
Old 03-16-2012, 09:43 PM   #3
Ravenworks's Avatar
Either burn it of until the engine dies,or add Stabil and fill the tank full to the top.
I always empty my power equipment and fog the engine.
Ravenworks is offline   Reply With Quote
Old 03-16-2012, 10:19 PM   #4
Too Short? Cut it Again!
I would drain it either by pulling the fuel line or burning it off. I always pulled the spark plug and cleaned and gapped it and sprayed a bit of WD40 into the opening. Replace the plug. Clean or replace any filters. Drain and change the oil when it is warm. Hose or powerwash off any salt and such. You will be good to go next winter.
Old 03-16-2012, 10:58 PM   #5
A Little Of Everything
Rewards Points: 1,356
If this is a 2-cycle, with oil mixed in the gas, I'd get it out of the tank. It'll gum up your carb.
If it's a regular 4-cycle engine, it probably won't be a problem.
DrHicks is offline   Reply With Quote
Old 03-17-2012, 12:02 AM   #6
Ravenworks's Avatar
Originally Posted by sdsester View Post
I I always pulled the spark plug and cleaned and gapped it and sprayed a bit of WD40 into the opening.
WD40 is good for the threads on the head,however WD40 is a VERY BAD thing to spray into a cylinder as it will wash away what little oil causing rust on the valves and cylinder walls.
A tablespoon of oil would be good,I always have a can of fogging oil so that is why I use it.
Old 03-17-2012, 08:35 AM   #7
I would argue only if it is full and I don't like storing more fuels than necessary. If the tank is only partially full, condensation can form and drip into the tank. The machine will sputter when you try to start it next winter and you will end up draining it anyhow.
2 cycle mixes of oil and gas most definitely have to be drained or burned off.
Old 03-17-2012, 08:46 AM   #8
Or, if it's like my 40-year old John Deere 826 snowblower, the gas just kind of finds places to leak out & I never have to drain the tank.
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Change a door from left hand to right hand? mhaucke Building & Construction 10 10-08-2007 12:18 AM
Old homeowner left this fertilizer....Should I use it? ConstantChange Landscaping & Lawn Care 2 04-24-2007 03:46 PM
thin film of oil on left front wheel bobo Automotive Repairs 15 04-11-2007 08:24 PM
tap turns water on when turning left or right? ebonysw45 Plumbing 4 03-04-2007 02:48 PM
