Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-26-2010, 01:32 PM   #1
Gas water heater thermostat
I'm in the process of replacing the thermostat on our gas water heater. Have got the new thermo. and it has 2 wire leads coming off of it to female spade connectors. The thermo. I'm replacing had these two wires incorporated into some type of terminal that was part of the thermocouple port. Long story short, what do I do with these two wires?
Thanks.
Mike
mikej1231 is offline   Reply With Quote
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-28-2010 12:00 AM
Replaced water heater, still smelling sulfur in hot water & Low water pressure aminus21 Plumbing 2 07-21-2010 05:40 PM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
Tankless Water Heater welshie Plumbing 12 03-03-2010 01:46 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
