Gas Stove Installation - Appliances - DIY Chatroom Home Improvement Forum
Old 08-07-2008, 03:12 PM   #1
Gas stove installation
I just bought a used gas stove and it did not come with the line to hook it up to my gas line in the kitchen, how do I figure out what size I need and then how do I hook it up properly?
leiana_thomas@yahoo.cm is offline   Reply With Quote
Old 08-08-2008, 04:23 PM   #2
Remove the fittings on the supply line and the range, go to hardware supply store so they can give you the right size for both ends. Make sure you get the updated flex line, cooper are no longer approved. Leake check with soap when you install the line.
CIT1336 is offline   Reply With Quote
Old 08-08-2008, 11:03 PM   #3
Thanks very much for the tips, I never would have thought of using soap to check the seals, that is super handy advice.
Old 08-09-2008, 12:00 PM   #4
jeff1's Avatar
Hi,
These may help.....
http://www.applianceaid.com/gasconnector.html
http://www.hammerzone.com/archives/p.../move/pipe.htm
jeff.
Appliance Repair Aid
JRAppliance
www.jrappliance.ca
jeff1 is offline   Reply With Quote
Old 09-25-2008, 03:25 AM   #5
I also do that, using soap to check the seals. It's effective and safe.
Last edited by AtlanticWBConst.; 09-25-2008 at 05:19 AM. Reason: SITE RULES VIOLATION: Advertising Links Removed From Signature
jmmv08 is offline   Reply With Quote
Old 09-25-2008, 03:55 AM   #6
Rewards Points: 60
Yes, even our gas company recommends using soap to check for leakage.
Last edited by AtlanticWBConst.; 09-25-2008 at 05:20 AM. Reason: SITE RULES VIOLATION: Advertising Links Removed From Signature
home decorations is offline   Reply With Quote
gas stove installation bigpun Appliances 3 01-13-2008 08:41 PM
Gas stove installation helpless handyman Plumbing 2 11-29-2007 05:56 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 05:32 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 05:06 PM
