-   -   Gas stove installation (http://www.diychatroom.com/f47/gas-stove-installation-24868/)
leiana_thomas@yahoo.cm 08-07-2008 03:12 PM
I just bought a used gas stove and it did not come with the line to hook it up to my gas line in the kitchen, how do I figure out what size I need and then how do I hook it up properly?
CIT1336 08-08-2008 04:23 PM
Remove the fittings on the supply line and the range, go to hardware supply store so they can give you the right size for both ends. Make sure you get the updated flex line, cooper are no longer approved. Leake check with soap when you install the line.
leiana_thomas@yahoo.cm 08-08-2008 11:03 PM
Thanks very much for the tips, I never would have thought of using soap to check the seals, that is super handy advice.
jeff1 08-09-2008 12:00 PM
Hi,
These may help.....
http://www.applianceaid.com/gasconnector.html
http://www.hammerzone.com/archives/p.../move/pipe.htm
jeff.
jmmv08 09-25-2008 03:25 AM
I also do that, using soap to check the seals. It's effective and safe.
home decorations 09-25-2008 03:55 AM
Yes, even our gas company recommends using soap to check for leakage. :)
