Gas Stove Ignitor Clicking - Appliances - DIY Chatroom Home Improvement Forum
Old 11-23-2013, 08:52 PM   #1
Gas stove ignitor clicking
My whirlpool counter top gas stove click continuous , without even turning the burner on.
All the burner sparks all the time.
Any help please
ryandeen is offline   Reply With Quote
Old 11-23-2013, 10:11 PM   #2
Rewards Points: 13,270
Going to need the model # to even guess.
Old 11-23-2013, 10:38 PM   #3
Rewards Points: 218
Any help please
I would unplug it, you may burn out the module running it continuously.
Here's a link with a similar problem which may be helpful. Post model number when you get a chance.
trouble shooting link
jmon is offline   Reply With Quote
Old 11-24-2013, 11:25 AM   #4
Model number. GLT3057RB01.
And yes I unplug it . I am good with multimeter.
I work on aircondition .
Old 11-24-2013, 11:28 AM   #5
My wife clean the stove and burner and then it happen, she probably short something out.
Old 11-24-2013, 11:43 AM   #6
Rewards Points: 218
Thanks for the part number. This is what poped up when I googled it. This is an excerpt from the manual:
CAUTIONARY NOTE:
Be sure to unplug the stove from the electrical power prior to testing.
Sparkers do go bad, so it could also be a defective one. Each sparker has a wire that pulls off the sparker element body. You can disconnect one at a time and test to see if the sparking stops.
If the sparking continues, then reconnect that one & disconnect another. Continuing with each sparker one at a time until you locate the one that may be causing the problem. The one that stops the sparking is the culprit.
If ALL the sparkers are sparking, the most likely cause is a defective capacitor in the spark modual. Spark moduals are not repairable. The entire part must be replaced. Replacements are available at the local appliance retail parts store listed in the phone book.
Another possibility is moisture during the cleaning process found it's way onto one or more of the switches. Excessively moist and or wet sponges or cleaning cloths allow water to get onto the switches, which will cause this problem, if applicable.
Attached is a manual (click on spark module), if you check out page 3, item 4, thats what the spark module looks like. Any appliance store should have them or you can call whirlpool. Hope it helps you.
spark module
Old 11-24-2013, 12:14 PM   #7
Oh thank you so much for that link, that is very helpful. I will let you know what happen.
Old 11-24-2013, 12:23 PM   #8
Rewards Points: 218
Your welcome, let us know how everything works out for you. Thanks.
Old 11-24-2013, 02:33 PM   #9
raylo32's Avatar
Rewards Points: 1,238
Sometimes after cleaning the stove the burner bodies that go over the gas outlets aren't perfectly seated or aligned and this can cause a no fire even though the igniter is clicking away. Happens to me all the time and I test them after cleaning to make sure everything is back to normal. Just a thought for something else you might check before tearing it apart...
Live long and prosper.
raylo32 is online now   Reply With Quote
The Following User Says Thank You to raylo32 For This Useful Post:
ryandeen (11-24-2013)
Old 11-24-2013, 05:05 PM   #10
Ok after reading that link that you send me, I open the oven top and test each switch for continuity with burner knob off. One show continuity , which is the culprit. I then used a hair dryer and blow air across the switch for a while to dry any moisture in it. Then test again and no continuity . Put everything back together and all work great again.
Thank you guys so much for the big help, and save me money.
Old 11-24-2013, 05:08 PM   #11
Jmon and raylo thanks again.
Anytime you guys in Charlotte nc , drinks is on me.
Old 11-24-2013, 05:14 PM   #12
Rewards Points: 218
Great. Glad everything worked out for you and you saved some money. Now you know what to do after cleaning it, if you get the contacts too wet. Thanks for sharing.
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 05:54 PM
Wood Stove, and Furnace hot water system shendog HVAC 7 10-04-2010 10:30 PM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 06:32 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 06:06 PM
