Gas Range Woes - Appliances - DIY Chatroom Home Improvement Forum
Old 10-24-2011, 05:23 PM   #1
Gas range woes
Ok, I moved into this house and it has a Sunbeam natural gas range (model # SNS3GMNSAW). It was manufactured in 2007, so it's not that old. Apparently this is their bottom-of-the line model, no bells or whistles, just 4 burners and an oven. Piece of crap doesn't even have a storage drawer under the oven. Anyway, no matter what burner I use, the damn thing burns my food, even at the lowest setting. For example, when making rice, after the water boils, I put the rice in, turn the burner all the way to low, cover the pot, and let it simmer for 20 minutes. But after about 10 minutes, the pot is overheating and the rice is sticking to the bottom of the pot. Tonight I made hamburger helper (yes, I live alone) and the instructions say that after it boils, cover, turn to low and simmer for 10 minutes. But even with the burner turned all the way to low, after about 5 minutes the skillet is bubbling over and spurting crap all over the stovetop. Any suggestions?
bpress54 is offline   Reply With Quote
Old 10-24-2011, 06:06 PM   #2
Get a wife.
Master of Cold is offline   Reply With Quote
Old 10-24-2011, 06:08 PM   #3
Just kidding
Pick the top up and see if there is an adjustment on the flute. It will be a collar with a screw. The collar will slide foreward and back. Also pull the range out and see if there is a regulator.
Old 10-24-2011, 06:34 PM   #4
Gas range woes
I had a wife, which is why I now live alone. And I'm not kidding. Anyway, this range appears to have what are referred to as sealed burners, they are attached directly to the top of the stove with screws and the top doesn't seem to want to lift off easily. I can pick it up a little bit, but the tubing underneath seems to be preventing it from lifting up all the way. I do see a regulator under there, but don't know how to access it. Yes, the stove is a piece of junk, but it's all I have right now so I don't want to eff it up. The burners have a plate that sits on top of an aluminum casting that encompasses the ignitor, and inside of that is a brass orifice
Old 10-24-2011, 08:15 PM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
do not try to lift the top up, you will kink or break your burner tubes unless you remove the burners first. If your knob is set on the lowest setting the tip of the flame should be just above the burner cap if it is any higher, the low setting can be adjusted at the burner valve. I'm not going to tell you how to adjust the low setting as I think that is something that should be done by a qualified service tech.
And by the way Sunbeam went bankrupt a few years back and replacement parts are impossible to find.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 10-24-2011, 08:42 PM   #6
Gas range woes
Thanx guys, I think I'll just call an appliance tech to check it out
Old 10-24-2011, 10:22 PM   #7
Rewards Points: 378
At least you have a stove. I used my Coleman 2 burner for a while when I became wifeless.
fireguy is offline   Reply With Quote
Old 10-24-2011, 10:25 PM   #8
gas range woes
Well, yea, but it's kind of useless if it just burns the crap out of whatever I'm trying to cook on it. That's why I got rid of my wife.
Old 10-25-2011, 05:43 AM   #9
Wonder if this thing was shipped/bought/whatever as LP and never converted to NP? flames high and yellow?
Jacques is offline   Reply With Quote
Old 10-25-2011, 07:28 AM   #10
Gas Range woes
No, flames are blue, and when turned to low are barely visible
Old 10-25-2011, 07:55 AM   #11
#1 HAWKEYE FAN
sounds to me like it is working as it is supposed to.
Fire the cook
Old 10-26-2011, 06:12 AM   #12
Fire the cook
Somewhere the EX is smiling.
Old 10-26-2011, 07:03 AM   #13
mem
Rewards Points: 156
Maybe some better quality cookware is in order. The cheapo stuff doesn't distribute the heat very well. And, hey, nuthin' wrong with hamburger helper!
mem is offline   Reply With Quote
Old 10-26-2011, 06:41 PM   #14
This is better though...
range hood opening is bigger than range hood jacks16 HVAC 2 06-23-2011 06:19 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
Drop in range versus self standing for narrow area sbrink Kitchen & Bath Remodeling 6 01-21-2011 10:17 AM
Moving Electric Range Plug dmartins Electrical 3 11-23-2010 07:48 AM
Had a new electric range installed in my apartment - does this sound right? SAABturboDRIVR Electrical 15 01-02-2010 05:39 AM
