Gas Range Vent?? - Appliances - DIY Chatroom Home Improvement Forum
Old 02-11-2013, 12:05 PM   #1
Rewards Points: 722
Gas Range Vent??
I am redoing the kitchen in my c1915 house. One of the main problems I'm having to contend with is how to vent a gas range. I'm holding off on my purchase until I get all the cabinets built and the room painted, etc., so my options are wide open at this point.
The problem is placing something above is out of the question. The range is in a box out with a shed roof and windows all around. That leaves me only with the options of pulling the air down and out or just staying with the old method of opening the window(s) surrounding the stove. Wife is not a fan of the Jen Aire's, she doesn't think the ovens are large enough due to the vent system. We had an older one in last house and my parents have a 4yr old one in their current house.
I've considered the pop-up style setups, but my reviews haven't brought up many positive reviews. They seem to be very loud and not very efficient at pulling out the fumes. The better ones are well over $1000 and that's tough to swallow on a, this might work, scenario.
I'm wondering if it would be possible to 'make' something. I actually have an old squirel cage, from old furnace, in a box I built, which I use to filter and suck air out of the house, when I'm creating dust. It has me wondering if I could just use something like that, as I believe some are variable speed, and just run some ducting up behind the stove along with a varaible switch. I have plenty of room in the crawl space under stove to place a fan. Another thought is to look for a good quality, scratch and dent fan, strip the components and use that minus the housing.
I'm curious has anyone ever done this, seen it done or have any suggestions? How high above the range should I place the vent if I attempt something like this?
I'll likely be using a 30" wide gas slide in range and I'm pulling this cabinet out 30" from the wall instead of the standard 24" due to a design detail, so I'll have about 6" behind the range for whatever I decide to do.
Thanks for any input and suggestions!
Master Brian is offline   Reply With Quote
Old 02-11-2013, 01:13 PM   #2
MarginallyQualified
Rewards Points: 2,464
You aren't required to vent a residential range.
The choices are just that but the methods carry some requirements.
That is indeed a problem.
...leaves me only with the options of pulling the air down and out
ayup.
Wife is not a fan of the Jen Aire's...
I've considered the pop-up style setups, but...
Now we're talkin!
I actually have an old squirel cage...
er, no.
...and just run some ducting up behind the stove...
Ok, we're back on track again.
Duct work in the wall studs.
Connect at top end to the ready made hood (with filters, lights)
that you (and TOWMBO) prefer. It can even have a fan built in.
At the basement (or crawl) level... adapt the duct work to round.
Install an inline fan LINK then more duct to a damper through side wall.
Wire the inline to work off the built in switch on the hood.
Old 02-11-2013, 10:23 PM   #3
Rewards Points: 940
I can see you now, standing in front of the range, stirring a pot of boiling pasta, with your necktie sticking straight out towards the exhaust.
cleveman is offline   Reply With Quote
Old 02-11-2013, 11:17 PM   #4
Rewards Points: 6,652
Most homes of that age, leak so much air, you do not have to worry. It is not until you make the home so tight, that you have to bring in fresh air, then you have worries & problems with venting, along with Positive & Negative pressures.
Old 02-12-2013, 11:34 AM   #5
Rewards Points: 722
ayup.
Now we're talkin!
er, no.
I've actually considered very heavily about NOT putting a fan in, but it'd be nice and I don't want to regret later.
I can't do a hood per say, but could fashion something into the wall directly behind the stove. Would be a lot like a pop-up style, with no pop up. Those in-line fans look like just the thing. Curious how loud they are, but I have been looking at Fantech's website and they sell silencers and backdraft dampers so that might be the way to go!
Thanks!
Old 02-12-2013, 12:21 PM   #6
Go into a local show room that has them set up. Then can range in various db. Most manufacturers will have available in the technical spec's the noise level or can answer if you call or email them to inquire the db level of the fans.
If you have a iPhone or Android, you can download Sound meter apps. I have the Audio Tools app on my iPhone, which has both an analog & digital sound meter, and both work very well in giving good readings.
The Following User Says Thank You to gregzoll For This Useful Post:
Master Brian (02-12-2013)
Old 02-12-2013, 02:21 PM   #7
Rewards Points: 722
Finding a show room that has what I want, I feel might be tricky. I will try the sound meter app, that's a great idea, thanks!
Old 02-12-2013, 02:26 PM   #8
We are lucky, due to a friend of ours owns an appliance show room, and would have no problem getting the info we need. May want to email the manufacturer and see if you are lucky to get an engineer to respond back. I was lucky when I emailed Leviton regarding their AFCI outlets, that I actually got a engineer to answer my questions regarding that new product line, vs. just some Customer Service rep who would not have the info to my questions.
Another item, check with local building companies, they may have customers already that use the same brand, and could possibly set up a way to contact them, to ask the questions regarding how they like the product, sound/noise issues, etc..
Old 02-12-2013, 03:21 PM   #9
MarginallyQualified
I can't do a hood per se, but...
What do you mean you "can't" ?
I tend to get my back up when people say can't...
99% of the time it's a way of saying something else.
There is really no substitute for having lights and a filter
(and the switches) immediately above the cooking surface.
You can call it whatever you like... but find a way to have that.
Especially if you will have a wall behind the stove top.
Curious how loud they are...
They work very well and aren't real loud.
Some are quieter than other (check their Db ratings)..
but they are all designed for the purpose.
Old 02-12-2013, 05:48 PM   #10
Rewards Points: 722
I mean just that, not possible. No way, no how! I guess one could redo a roof to make it possible and remove a window, but I'll just say I can't!! It is a shed style roof with windows wrapped all the way around. Except for maybe 10-12" between top of counter and bottom of window(s) the rest is structural framing and windows. The ceiling directly above the range is 7' at the highest part.
There is maybe 5-6" between top of window and bottom of roof line (read Header) and the roof line is 2x4" framing. In order to clear the windows, the hood would have to be about 42" above the top of the cooktop and they seem to say much over 30" isn't doing any good.
I'm sure this is the way I'll go and just build a vent into the wall behind the cooktop! Surely, I can fab something up for that!!
dryer/bathroom vent terminations and window clearances itsnotrequired HVAC 14 04-29-2012 08:55 PM
dryer and range hood vent Mhm HVAC 0 12-11-2011 11:08 PM
what is the best way to seal an old unused range vent duct? jimnsulaw17 General DIY Discussions 1 11-21-2010 08:11 AM
Connecting duct for range hood vent UAL767 HVAC 9 01-31-2010 02:18 PM
Under cabinet range vent mounting problem biosfreak General DIY Discussions 3 07-15-2009 01:36 PM
