Gas Range Swap - Appliances - DIY Chatroom Home Improvement Forum
Old 03-05-2007, 02:18 PM   #1
gas range swap
I have a 8 year old whirlpool gas range that i want to replace with another brand new whirlpool gas range. I would like to know if I can just use the existing gas pipes/connectors and anti-tip brackets for the new one. Therefore, I would not need to bother with too much installation hassles. Just disconnect, pull out old range, re-connect new range, and push in. Is this possible?
kenny11876 is offline   Reply With Quote
Old 03-05-2007, 07:37 PM   #2
Rewards Points: 150
It should be relatively simple, 8 years isn't long at all...
But to be safe I would turn the gas line off, unscrew it and take a picture/draw/measure the gas line and brackets, and then bring it to the store...
elementx440 is offline   Reply With Quote
Old 02-20-2008, 08:31 PM   #3
Your gas connections are likely the same, 1/2" pipe with adapters to flare thread fittings for the flex connector. If there is any doubt about the integrity of the old flex, replace it. New ones come with the pipe thread adapters for each end.
Anti-tip brackets vary with the best ideas of the manufacturer at the time of design. If you stick with Whirlpool brand, it's possible (but not absolute) the new one could have the same type of bracket.
jimmyj555 is offline   Reply With Quote
Drop In Range Hook-Up mickey45 Electrical 1 04-08-2007 09:29 PM
What should I pay..... stevenblick General DIY Discussions 5 02-19-2007 07:38 PM
Home, home and the range! ...A dimensional query. Hushpuppy Carpentry 4 05-26-2006 06:23 PM
Can I Wire a range hood to an exhisting outlet? skellies Electrical 2 05-09-2006 04:06 PM
Replacing Stove Top with Range the.vicster Electrical 3 02-23-2006 05:12 PM
