Gas Range - Oven Isn't Working But Burners Do Work - Appliances - DIY Chatroom Home Improvement Forum
Old 03-24-2012, 09:20 AM   #1
Gas range - oven isn't working but burners do work
Hi all,
I bought this old GE oven and I didn't check if the oven works.... The burners work fine but the oven doesn't light up.
Any idea how I can fix it?
greendot is offline   Reply With Quote
The Following User Says Thank You to greendot For This Useful Post:
djcosen (07-01-2015)
Old 03-24-2012, 08:11 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
most likely the oven ignitor is bad, you'll have to take the ignitor out and replace it
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 03-24-2012, 09:24 PM   #3
How do I do that?
Is it an electrical thing?
Old 03-25-2012, 06:57 AM   #4
the Musigician
DangerMouse's Avatar
Originally Posted by greendot View Post
How do I do that?
Yes, it is. Is the unit plugged in? If so, you may need to replace the part.
Check first to be assured the connection is tight.
DM
Old 03-26-2012, 02:34 PM   #5
DIY Junkie!!
Rewards Points: 182
Hi all,
I can't tell from the photo (other than to think it is a self-cleaning oven b/c of the lever at the top of the oven door), but it might be something simple like the thermocouple on the oven.
If your stove has pilot lights, see if you can light the pilot for the oven. If the thermocouple is bad, the pilot light flame will go out once you remove the match/lighter from the pilot light area.
If it has piezoelectric spark pilots, well, the others are undoubtedly correct.
[OT---great to see ya, again, DangerMouse....I have been on the site off and on for about 6 months and hadn't seen you posting again, thought you might have moved on!].
Cheers!
Dugly
YerDugliness is offline   Reply With Quote
Old 03-26-2012, 02:40 PM   #6
the Musigician
Hey Duggy! You should know better.... they keep me chained quite securely here.
DM
Old 03-29-2012, 10:03 PM   #7
Missouri Bound's Avatar
How do I do that?
Well I doubt you have pilot lights, so it's electronic ignition....does it "click" when you turn on a burner?
There is a a device beneath the bottom panel of the oven which basically does the same thing. It's a "glow plug" of sorts which ignites the fuel. You can find the parts online if you get the stove model number.
Do you want it your way or the right way?
Old 03-30-2012, 07:22 AM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
Gas ranges with glow ignitors have 2 of them, 1 in the bottom of the oven for the "bake" setting and 1 in the top of the oven for the "broil" setting. Try the broil setting, if that works replace the bottom ignitor. If neither bake or broil works, I doubt that both ignitors have gone bad.
BTW, those glow ignitors are shock sensitive and can be damaged while moving.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 03-30-2012, 08:10 AM   #9
I think the best thing for you to do is call the customer service of GE. Let them do their job and fix it. As RJnile said the glow ignitors are shock sensitive. if you break it your warranty will be void.
I have experience the same problem and did as I have mentioned here. They have a good service and they fix it fast!
lloyd86 is offline   Reply With Quote
GE Monogram range burners won't light ChuckH Appliances 3 11-09-2016 05:30 PM
Dispute: Oven malfunction after h/w guys used the circuit rational Appliances 18 05-17-2011 10:37 PM
Moving Electric Range Plug dmartins Electrical 3 11-23-2010 07:48 AM
Oven Door question for Amana Gas Range ChrisJJ Appliances 1 09-13-2010 06:48 AM
Gas oven does not work; pilot light on, stovetop works fine kathleentsy Appliances 1 05-22-2007 05:05 PM
