Gas Range/oven Installation - Appliances - DIY Chatroom Home Improvement Forum
Old 11-11-2010, 12:58 PM   #1
gas range/oven installation
Is there anything special I should know before installing a gas range/oven? If the gas valve is off until I'm done, is there any danger?
neongoddess is offline   Reply With Quote
Old 11-11-2010, 10:30 PM   #2
HVAC / Plumbing
I like to cap off any gas lines that aren't connected.
kenmac is offline   Reply With Quote
Old 11-12-2010, 06:10 AM   #3
if it has a flex line don't reuse- buy new one-even if it looks ok. don't tape/paste the compression nut [2nd nut] do tape or paste all other connections. leak check all connections after hook-up.
Jacques is offline   Reply With Quote
Old 11-12-2010, 08:14 PM   #4
How do you check for leaks?
Old 11-12-2010, 09:27 PM   #5
Rewards Points: 150
Dip a sponge in soapy water. Wipe around the the newly installed line near the valve. If it bubbles, there's a leak. This is old school way of detecting gas leak that my dad taught me. Others may have better suggestions.
MagicalHome is offline   Reply With Quote
Old 11-13-2010, 09:53 AM   #6
when they couldn't smell anything; old school Gas Co guys used a match .
casement windows installation versus double hung installation user82106 Building & Construction 2 06-16-2010 06:56 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 01:19 AM
Electricl Installation for Electric Tankless Water Heater Educator Electrical 13 07-06-2008 11:27 AM
SubStandard Roofing Installation Fred213 Roofing/Siding 11 05-06-2008 01:15 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
