Gas Range Not Lighting - Appliances - DIY Chatroom Home Improvement Forum
Old 12-04-2009, 06:10 PM   #1
We recently discovered that our Gas Range is not working properly. We had to replace the igniter for the Oven a few months back as it was not staying lit, and since then it worked fine.
However when I went to turn it on just the other day, it would not ignite, nor could we ignite it with a match. There was no odor, so it seems that gas it not even flowing in properly. The stove top burners all work and light, and the Broiler does as well.
Apparently on thanks giving day there was a small fire inside the oven, from what I do not know. Could this have tripped some saftey mechanism designed to prevent major fire damage?
Or is this some other issue? The Electronic Control board seems to work correctly and does not display any errors.
GloomerO1 is offline   Reply With Quote
Long Range Outdoor Lighting Savageriver Electrical 7 10-18-2009 04:35 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 08:06 AM
