Gas Range Burners Sputter - Appliances - DIY Chatroom Home Improvement Forum
Old 01-27-2011, 08:13 PM   #1
gas range burners sputter
Our GE XL44 propane range just started acting up after a decade of trouble free service. The top burners sputter periodically. They light fine but every 10 to 15 seconds about half the flames of the burner will go out for a second and then come back, like a ghostly wind just blew by. Twice now they've even gone out, spewing unburned gas into the kitchen. It's like we got a bad batch of propane or something - is that possible? Any ideas for cause and cure?
klimshelf is offline   Reply With Quote
Old 01-27-2011, 09:24 PM   #2
A Little Of Everything
Rewards Points: 1,364
Is it possible that there's something wonky with your regulator?
The reason I ask, is because one time many years ago we had weird problems like this with our stove & furnace. Turns out there was ice built up on the outdoor regulator and it wasn't working properly.
DrHicks is offline   Reply With Quote
Old 01-28-2011, 05:32 AM   #3
Usually it's bad gas.
Jacques is offline   Reply With Quote
Old 01-28-2011, 11:00 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,012
Ayuh,... I had a problem like that a few years ago...
At about the time freezing weather showed up, it just plain Quit workin' all together...
I called my gas supplier,...
They, 'n the guy that came over claimed that it's Impossible for water to be in the system...
After abit of arguing in the driveway, the guy pumped in a few ounces of methanol....
Haven't had a problem since.....
Old 01-28-2011, 11:55 AM   #5
Experienced
Jackofall1's Avatar
How's your furnace running, is it showing similar signs or incomplete combustion?
Is the flame on the furnace not steady?
If they are both (furnace and stove) are showing similar signs I would be looking at the regulator. If its just the stove, did a spider make a web in the air injection part of the burner?
Old 01-28-2011, 04:09 PM   #6
Now today the burners are fine, no sputters. We don't have a gas furnace to compare flames. Temps here are mild, 30s to 60s. I'm thinking the last batch of propane had some water in it that worked its way through the lines causing sputter and now its gone. Does that sound plausible?
Old 01-28-2011, 04:46 PM   #7
Bondo's Avatar
Ayuh,... Very possible,...
I'd still ask 'em to ethanol the tanks though...
Old 01-28-2011, 05:06 PM   #8
Household Handyman
Rewards Points: 1,408
Used to have a house with LP gas heat, cooking. YES, that has happened to me and it was water in the line. The gas company did deny this until I went down to the office and threatened to go to the County about it. The came out, removed some gas from the tank and tested it (?) with some type meter, no water vapor. Then they removed the line at the house and did the same, high water vapor. No idea of how it got there though. The did flush the entire system from tank to each appliance with another gas, may be nitrogen, to dry it out, the all was fine.
Old 01-28-2011, 05:09 PM   #9
When it comes to demanding that your gas company check out and/or clean your line, keep in mind that it might be at your own expense. It will depend largely on whether you own the LP tank, or are leasing it. It will also depend on contractual details, because it might stipulate that you are responsible for the line from the tank to the house.
Old 01-28-2011, 10:44 PM   #10
Rewards Points: 372
Or the regulator at the stove could be "wonky". I have not seen problems with the outside regulator, but have with the appliance regulator. You do have a regulator at the stove?
fireguy is offline   Reply With Quote
Old 01-29-2011, 11:09 AM   #11
Fireguy, there is no regulator at the stove. Since all the burners are working fine now I think it must have been moisture in the line that has cleared. It is no longer broke so I ain't gonna spend time fixing it. Thanks to everyone for your input. This is a great forum!
Old 01-29-2011, 12:54 PM   #12
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
there would be no regulator at the stove, there would be a regulator in the stove.
hardwareman is offline   Reply With Quote
Old 01-29-2011, 05:21 PM   #13
Rewards Points: 372
That may be. I do not do residential, just commercial gas. A commercial gas range is supposed to have a regulator, but I find many do not.
Old 01-29-2011, 06:18 PM   #14
Our farm house, up in Minnesota, had 3 regulators. 1 on the LP tank, 1 on the outside of the house, and 1 on/in the stove. I'm not sure if that was a rather antiquated set-up, or what.
Old 01-29-2011, 06:54 PM   #15
Rewards Points: 372
Depending on the BTUs required, the length of the pipe, the size of the pipe, the type of appliances, sometimes higher pressure is needed to supply enough gas to the appliances. But, the cooking appliances I have worked on use low pressure, I think usually 5 to 7 pounds of water pressure. My gas code books are in the Sprinter, which is at my shop. Commercial gas stoves, grilles, charbroilers, woks, require a regulator for each open flame appliance. Some ovens and fryers have a gas valve with a built in regualtor. If I am installing appliances, I always take regulators with me, some customers toss them in the trash along with the installation manuals.
Klimshelf, the regulator has a purpose, to regulate the amount of fuel gas going into the stove. If there is an overpressure of the gas supply, you will have a large flame to contend with. Your personal safety is your concern. I assume you are a single person with no family or neighbors to be responsible for/to. But, you might go online and see if the manufacturer lists a regulator for your appliance. Try Fixya.com
GE Monogram range burners won't light ChuckH Appliances 3 11-09-2016 05:30 PM
Drop in range versus self standing for narrow area sbrink Kitchen & Bath Remodeling 6 01-21-2011 10:17 AM
Moving Electric Range Plug dmartins Electrical 3 11-23-2010 07:48 AM
Old gas kenmore range....no oven, but burners work shadango Appliances 24 11-17-2010 06:45 AM
Had a new electric range installed in my apartment - does this sound right? SAABturboDRIVR Electrical 15 01-02-2010 05:39 AM
