Gas (propane) Cooktop Off A BBQ Tank - Appliances - DIY Chatroom Home Improvement Forum
Old 06-26-2010, 09:21 AM   #1
gas (propane) cooktop off a BBQ tank
for several years our country house was heated with propane.
During that time we rented 2 huge propane tanks from the local supplier.
We recently removed the gas heating and so the only propane use that remains is a gas cooktop (converted to propane supply).
Since we only use the place for about 10 days a month, the propane use has gone from significant to tiny.
The propane supplier removed their rental tanks (saying we weren't using enough propane for it to make sense - they are correct.)
we now need an alternate propane supply.
given how little we use (maybe boiling a pot of water each day) I would like to just use a regular refillable BBQ propane tank.
I've rigged one up with appropriate adaptors. but it is about...100feet from the actual propane cook top.
on my first test, the burners lit - reluctantly it seems. turning everything off and trying again, it doesn't light at all. (it was working perfectly before the large tanks were removed.)
I can smell and hear the propane but it doesn't light - either with the clicker or a match.
Is there any reason this should NOT work?
different pressure?
too long a distance?
pstock is offline   Reply With Quote
Propane Mower Conversion homerb Green Home Improvement 21 03-16-2016 04:42 PM
Propane Range hookup to 20lbs tank? PaoloM HVAC 0 06-09-2010 10:47 AM
propane tank switch. waverly guy HVAC 13 09-14-2009 08:25 AM
Propane Tank for BBQ Irregular WayPeter General DIY Discussions 4 03-03-2009 01:28 AM
Propane tank was empty boiler does not start schrubber HVAC 3 12-30-2008 04:36 PM
