Gas Pressure IN House,,, - Appliances - DIY Chatroom Home Improvement Forum
Old 11-12-2008, 07:26 AM   #1
gas pressure IN house,,,
have to reinstall our gas-fired drop-in cooktop in new cabinet,,, there's a drawer just under it which'll work IF i remove the unit's gas regulator/valve to another location,,, IF i do this, will it meet any code regulations ? ? ? new c-tops will be 2" granite.
thinking i'll mount it under the floor in bsmt onto a floor joist - approx 4' from the unit's gas inlet,,, in the meantime, contacting our natl gas supplier,,, appreciate any replies/suggestions,,, if i remember right, pressure INSIDE the house's in the 4-6psi range, right ? ? ?
THANKS in advance ! ! !
yesitsconcrete is offline   Reply With Quote
Old 11-12-2008, 11:12 AM   #2
you may find hvac-talk.com helpful i thing theres a code forum there sorry i cant help more
kennzz05 is offline   Reply With Quote
Old 11-16-2008, 06:48 AM   #3
whirlpoop was no help at all because of their liability,,, appliance repairmen, ditto,,, gas transmission & supply people, nada,,, finally an installer told me the device must be in the same room - 2' is wonderful
Old 12-04-2010, 03:24 AM   #4
Rewards Points: 1,192
I'm an electrician,but I think you mean 4-6 oz,not lbs pressure.
bobelectric is offline   Reply With Quote
Old 12-06-2010, 06:19 PM   #5
HVAC / Plumbing
That would be 4''-6'' WC
kenmac is offline   Reply With Quote
Old 12-06-2010, 06:26 PM   #6
Experienced
Jackofall1's Avatar
Keep this in mind the further you put the valve the more line that has to purge in order to light. I would keep it as close as possible.
Is modifying the drawer an option?
Old 12-06-2010, 08:48 PM   #7
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
[quote=Jackofall1;546915]Keep this in mind the further you put the valve the more line that has to purge in order to light. I would keep it as close as possible.
except on the initial start up after installation, it would not have to purge at all.
hardwareman is offline   Reply With Quote
Old 12-06-2010, 09:12 PM   #8
firehawkmph's Avatar
Rewards Points: 1,922
Yes,
I run into this all the time when installing kitchens. I used to make the drawer a dummy until one day I was looking at it and decided to keep the drawer functional. I cut a notch in the back of the drawer and using the cutout pieces, boxed it back in around the gas valve. It only took about ten minutes and looked like it was made that way.
Mike Hawkins
firehawkmph is online now   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
DrHicks (12-06-2010)
Old 12-06-2010, 10:13 PM   #9
Experienced
Jackofall1's Avatar
Originally Posted by firehawkmph View Post
Yes,
Mike Hawkins
Mike,
Thats exactly what I was talking about. Mod the drawer not the gas service.
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Patio roof to house attachment question mikemobile Building & Construction 1 09-30-2008 07:51 AM
EXcessive moisture in house geema HVAC 5 09-10-2008 11:18 AM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 05:42 PM
Loss of water pressure in my house... stormyjas Plumbing 6 02-15-2007 10:36 AM
