Gas Oven Won't Work When Boiler Is On - Appliances - DIY Chatroom Home Improvement Forum
Old 01-28-2013, 01:34 PM   #1
Rewards Points: 12
Gas oven won't work when boiler is on
Since I got so much help with the bleeding radiator questions, I'd thought I'd throw my other problem out for suggestions. When my new gas boiler was installed a few years back, I noticed the gas oven wouldn't work. I told the installer before he left, but when I showed him, it did work. I thought the oven was the problem. One winter passed before I made the connection. The oven will work only when the boiler is not working. Now when I use the oven, I turn the temp down to 55, cook, and then turn the temp back up. There has got to be a better way?
hubbard is offline   Reply With Quote
Old 01-28-2013, 01:41 PM   #2
Rewards Points: 12,804
Think I'd be checking the incoming to the unit with a meter while the boiler was running to see what happens.
Old 01-28-2013, 03:15 PM   #3
An old Tradesmen
Rewards Points: 6,086
Did the installer run a new gas pipe from the meter to the boiler. Or just reuse the pipe that was there. I know its hard to remember things from a few years back, but is there any chance the installer put in a large boiler then what was there.
Old 01-28-2013, 09:25 PM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,582
you need to do a gas pressure check at the stove when the boiler is running, sounds like you do not have enough gas pressure. Probably undersized incoming gas line.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Boiler system not completely filling? jeffro83 HVAC 9 08-31-2012 12:56 PM
Dual fuel range, oven doesn't work. bkvanbek Appliances 16 10-02-2011 04:31 PM
4 burners on stove work, OVEN DONT!! tystaylor Appliances 3 04-18-2009 01:56 AM
Will an Apollo 3 way ball valve work like I think? Piedmont Plumbing 2 04-01-2009 05:34 PM
