-   -   Gas oven won't work when boiler is on (http://www.diychatroom.com/f47/gas-oven-wont-work-when-boiler-170368/)
hubbard 01-28-2013 12:34 PM
Since I got so much help with the bleeding radiator questions, I'd thought I'd throw my other problem out for suggestions. When my new gas boiler was installed a few years back, I noticed the gas oven wouldn't work. I told the installer before he left, but when I showed him, it did work. I thought the oven was the problem. One winter passed before I made the connection. The oven will work only when the boiler is not working. Now when I use the oven, I turn the temp down to 55, cook, and then turn the temp back up. There has got to be a better way?
joecaption 01-28-2013 12:41 PM
Think I'd be checking the incoming to the unit with a meter while the boiler was running to see what happens.
beenthere 01-28-2013 02:15 PM
Did the installer run a new gas pipe from the meter to the boiler. Or just reuse the pipe that was there. I know its hard to remember things from a few years back, but is there any chance the installer put in a large boiler then what was there.
hardwareman 01-28-2013 08:25 PM
you need to do a gas pressure check at the stove when the boiler is running, sounds like you do not have enough gas pressure. Probably undersized incoming gas line.
