#1 |
Gas Oven Won't Ignite
the oven gas turns on, but won't ignite. we have had the oven for 7 years and it has given us problems from the beggining, but whirlpool won't do a thing about it, they say "it's not their problem, must have been a bad unit." Not the answer I need to hear. Can anyone help?
#2 |
assuming you have direct ignition. this is not a DYI job. you need to call a local guy that knows this system [ask]. sometimes, sadly though, it never gets permantley repaired.
#3 |
Not sure of the exact nature of your problem, but I had a recent experience with a nearly new maytag gemini that was similar in nature and possibly scope. Purchased on Black Friday, had a service tech out last month to repair/replace parts. Apparently the ignitor goes bad prematurely, and being the voltage going to the ignitor wasn't enough to open the gas line to allow gas out. This could very well be your issue, and I wish you the best of luck towards a resolution of this.
#4 |
fabrk8r
As wikkie650 already suggested, replace the ignitor. The gas valve won't open if it senses that the ignitor has an open circuit. Fairly common with gas ranges due to the temperature extremes and the fact that the ignitor is encased in a fragile ceramic block.
Go to your local appliance part supplier, Dey for example, and give them the model and serial number. be prepared for sticker shock, they sell for anywhere from $35.00 - $75.00.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright |
| Display Modes | |
| SCARY oven fire! Why did it burn? | Beth777 | Appliances | 63 | 01-20-2013 07:55 PM |
| Oven Install and Replacement- Dacor $400 | CostcoMan | Appliances | 1 | 05-24-2010 07:02 AM |
| Gas oven problems | gregsmy | Appliances | 1 | 12-03-2009 06:55 AM |
| Oven Blew Up at Connector with Element | cynthiap | Appliances | 5 | 11-26-2008 07:30 PM |
| Gas oven does not work; pilot light on, stovetop works fine | kathleentsy | Appliances | 1 | 05-22-2007 06:05 PM |
