Gas Oven Stops Heating - Help! - Appliances - DIY Chatroom Home Improvement Forum
Old 04-12-2013, 06:14 PM   #1
Rewards Points: 81
Gas oven stops heating - help!
Our oven will sometimes stop heating. The display will still show the temperature and the timer will still count down, but when I open the door the food isnt cooked and it's only like 100 degrees in there. It's warmer than room temp so it obviously started to heat.
This has only happened twice and at random times. I baked dog treats for like 5 hours the other day without any issues. But today I tried to cook enchiladas for a half hour and it happened.
Any idea what this could be?
Total Tool is offline   Reply With Quote
Old 04-12-2013, 06:59 PM   #2
Always learning...
fetzer85's Avatar
Rewards Points: 262
Gas or electric and approx how old is it?
fetzer85 is offline   Reply With Quote
Old 04-12-2013, 07:04 PM   #3
Rewards Points: 81
Gas and 3 or 4 years old. Brand is Whirlpool.
Both times it happened we were using the timer. Probably a coincidence, but thought I would throw that out there if it might help the diagnoses.
Old 04-12-2013, 07:58 PM   #4
Rewards Points: 13,712
The timer is just that, it times the cooking time and has nothing to do with the the gas turning on and off.
Old 04-12-2013, 09:02 PM   #5
Always learning...
fetzer85's Avatar
Rewards Points: 262
Hmm...I have more experience w/ electric so I'll have to defer to someone else...good luck.
Old 04-13-2013, 11:31 AM   #6
r0ckstarr's Avatar
Rewards Points: 2,052
I'm not saying that you're wrong, but the gas/heat on my oven will shut off when the timer reaches zero.
r0ckstarr is offline   Reply With Quote
Old 04-18-2013, 09:17 PM   #7
Stove not heating
Mine went out couple months back..try if you haven't already is Flat Ignitor Igniter 31940001 Y0316223 0316223 you probably have 2 in there. Try you tube
http://m.youtube.com/watch?v=dwy73ktp7QU
GRed is offline   Reply With Quote
Clearance for double oven installation Steeler99 Building & Construction 1 01-30-2011 05:16 PM
furnace stops heating ashmay HVAC 1 01-16-2011 11:05 AM
Extending finished attic insulation stops? Mitch H HVAC 2 12-09-2009 11:00 AM
gas oven isn't heating deerhide Appliances 2 06-24-2009 03:16 PM
Baseboard Heating Stops Getting as Hot as it Used To? kali Plumbing 7 02-12-2009 03:08 PM
