Gas Oven Not Getting Hot Enough - Appliances - DIY Chatroom Home Improvement Forum
Old 10-18-2009, 01:45 PM   #1
Angry
gas oven not getting hot enough
i have a hotpoint gas cooker/oven which takes ages to cook food.could it be faulty thermostat not allowing cooker to reach correct temperature? if so how can you check this out? any help much appreciated.thanks Andy
festersvan is offline   Reply With Quote
Old 10-20-2009, 12:12 AM   #2
GetYourShineBox's Avatar
could be the t-stat. it could either be bad or need adjusting.
could be the oven burner is clogged/dirty.
could be the oven door gasket. (doubtful)
most likely the burner or t-stat.
GetYourShineBox is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 03:19 PM
Oven Blew Up at Connector with Element cynthiap Appliances 6 10-31-2015 10:48 AM
Counter top trim to fit with slide in oven bhagey Appliances 1 07-17-2009 09:32 AM
